Replacing JD 1219 float spring
MarkinMo
07-06-2006 08:33:42
Has anyone replaced the large float spring on a JD 1219/1209 mower conditioner? I broke the left outer one and have ordered a replacment. I'm wondering how to remove the large nut on the top side that seems to be threaded onto the spring. Can't find much about it in the operator's or service manuals.
Allan In NE
07-06-2006 12:54:50
 Re: Replacing JD 1219 float spring in reply to MarkinMo, 07-06-2006 08:33:42
I did that this spring on my NH. The end pieces came with the spring.
Hang on, that job is a stinker! :>)
Allan
JMS/MN
07-06-2006 09:17:21
Not exactly sure what yours is like, but generally they are cast iron ends that thread into the spring. Since your spring is broken, you can just torch the spring away. If you want to unscrew it, put the spring in a vice- so the threaded area sticks out beyond the vice. Don't clamp down on the threaded area. Bad thing about those cast ends is that they are cast, not machined, so usually have a taper to the head and a wrench does not fit well. I usually use a pipe wrench on them.
MarkinMo
07-06-2006 09:32:24
 Re: Replacing JD 1219 float spring in reply to JMS/MN, 07-06-2006 09:17:21
Thanks for the info. What you have described is what mine is. I don't have a torch available so will have to try the vice method.
JMS/MN
07-06-2006 09:43:45
 Re: Replacing JD 1219 float spring in reply to MarkinMo, 07-06-2006 09:32:24
A portable grinder could also be used to cut the spring off.
MarkinMo
07-06-2006 10:20:54
 Re: Replacing JD 1219 float spring in reply to JMS/MN, 07-06-2006 09:43:45
I was able to get the outer spring off using the vice and large wrench. Now if my replacement sping shows up today at the JD dealer I'll be set. Thanks again!
