Old pull-type Servis mower
fixitforfree
07-04-2006 18:32:50
Any of you own or ever use an old Servis model E60 pull type mower? It is a 5" cut with a single HUGE gearbox and 2 brush cutter type blades. I have located one to buy but it is missing the driveline. I also wonder what ratio the gearbox is - is it relatively high speed where it will cut grass good? I have a newer Rhino CY60 3pt. type mower and it is tough but the gearbox ratio is so slow it won"t cut grass very good unless you go slow. Give me any comments on this Servis E60 unit you have. Thanks.
John A.
07-04-2006 22:53:24
 Re: Old pull-type Servis mower in reply to fixitforfree, 07-04-2006 18:32:50
fixitforfree, I have been around these old shredders, they are one tough shredder, they will take all you can dish out to it and keep on smiling. I have wanted a 6 or 7 drag type to put behind my ol M. The Servis Company was taken into the Rhino company. Any parts needed a local Rhino dealer should be able to get you parts.
The dual blade design allows for double cutting on each rotation of the blades. Also there is suppose to be stationary blades that mounts to the frame of the shredder. They stick out into the void area inbetween the 2 swinging blades on each end of the blade mount main beam. This is for extra cutting of crop at a given time. The blade asemble looks simular to this diagram below.
Most older shredders need to be run at High Idle to get max preformance. Also you may need to sharpen the blades, that will help more than you will ever know. Hope this helps.
Later,
John A.
fixitforfree
07-05-2006 16:23:22
 Re: Old pull-type Servis mower in reply to John A., 07-04-2006 22:53:24
Thanks for the info. A friend of mine has the one I am looking at. I have never used it. I called Rhino and they say it's serial #8252 means it is late 50's to early 60's model. It is all there and in great shape except the tires and it is missing the entire driveline. This worries me... Rhino said it is a 1:1 gearbox which is so slow... I want something that will give a great cut in grass so I will likely put a higher speed gearbox on it. Keep in mind, the this E60 is a drag type (Rhino said they were also available in a 3 pt. version). Have you used a drag type model? It looks like it takes an "odd" driveline that isn't splined to the input shaft put slides over the shaft then has a shear bolt the bolts through two steel discs on the driveline. Is this correct? Thanks for any help.
John A.
07-05-2006 20:08:44
 Re: Old pull-type Servis mower in reply to fixitforfree, 07-05-2006 16:23:22
fixitforfree, First of all, in just grass, Sharp Blades will be the biggest one single point for a well manicures look. Unless you are mowing over saay 10 acres, Gear down, throttle up!!! these old shredders are as I said before....Idot/bullit proof. So do not worry about running at high idle. the governor will keep ypour engine at 1750 or so and the shredder will run at 540 in and 540 out if it is 1:1 as they say. I have seen these old girls in trash 3ft tall,behind a Farmall M or H and just smile. So I would not think thaat swappin out gear boxes is worth the time ans surenogh the money.
Rhino should be able to get new drive line or update to a new style of some variety or another.
That shear bolt setup was pretty common back then.
Yes I pull a drag type now! A Rhino SR-15M, on 540 gear boxes, we use a JD 4230 (100 hp) tractor to pull it, I have pulled it with my 966 also. Either tractor will swing the pi$$ out of this ol girl.
I shred down all weeds/grass, and trees up to 4in diaameter, and 8 ft tall or so. We are in a pasture reclamaation mode right now so we do require a lot of a shredder, Yes I have twisted 2 drivelines, blown 3 sets of slip clutches, and thrown 3 different blades. The blade bolts are a weak point in my opinion, But I run one harder than most folks. the average farmer/rancher won't work one as hard as I do. All in All this is the toughest shredder I have ever run,Period,
Years ago some of the first grass mowers were ground wheel drive. Old truck rearends with a blade afixed to the front pinion yolk, pointed downward. with a hitch assembly welded on to hook to a tractor. Also to keep a well manicured pasture area, Don't let it get very tall between mowings. The taller the crop the harder it is to get it chopped up to look manicured. hope this helps.
Later,
John A.
