Ace PTO belt driven centrifugal pump.....leaks
mnjoe
07-04-2006 15:08:10
Cleaned tank with cleaner...new tips..replaced bad nozzles...setup and found gallons to acre. Filled sprayer with Genesie Extra for 20 acres. Pump started to leak a bit. Pump was primed and worked good with water. About 8 acres of spray in unit. Will the leak get worst fast? Should I pull the pump out to rebuild or finish sprayng and clean the tank and booms out. How hard are they to repair? I'm dripping about 1 1/2 gallons in 24 hours. Thanks for the advise.
kevin1234
02-12-2007 09:37:00
 Re: Ace PTO belt driven centrifugal pump.....leaks in reply to mnjoe, 07-04-2006 15:08:10
For all the trouble you go through to rebuild the pump, you should just get a new one. The have good deals on ebay or sprayparts4less.com
JMS/MN
07-04-2006 21:32:23
When a pump starts to leak, it can go at any time. Is there a shutoff valve on the tank? Should have one for that reason. They need to be checked each year to make sure they work. 8 acres left- how long does that take? Less than an hour? Hypro pump seal was $15-20, similar to ACE- did one this year. Just follow directions for ceramic seal- regarding direction and surface contamination issues-
Nebraska Cowman
07-04-2006 16:36:14
I'd finish sprayin'
