Remova; of Bolts in bolted Sickle
pbutler
07-04-2006 14:27:21
I broke a sickle section off on my 450 sickle mower-bolt on sections. The one that broke is near the head-with the section sandwiched between top and bottom. I need to drive the bolts out to replace it.
I didn't think it would be a big deal but I have beat on it with a 3lb hammer and it is starting to look like a rivet on top-but not budging.
I am about to break out the torch but not sure where to heat?
Any tips on removing those stubborn little bolts?
I hate to dump $65 to change a sickle section but has anyone tried this?
http://www.sickleservice.com/article.php?news_id=10
JMS/MN
07-04-2006 21:39:49
 Re: Remova; of Bolts in bolted Sickle in reply to pbutler, 07-04-2006 14:27:21
What mlm says will work, or you can buy the tool for maybe $15-20. Cheaper than the one with two ends for removing and installing rivets. If you use a hammer, you also need a punch and lower support like what mlm does. Doesn't do any good to bang on something hanging in the air, and no need to remove anything, or break out the torch. Just slide the sickle side to side to get enough room to work on the bolt in question. Don't understand the $65 thing.
msb
07-04-2006 17:10:43
Deere and others ,probably, sell the tools to remove and replace those bolts.Nieither will break the bank.
Nebraska Cowman
07-04-2006 15:20:08
Assuming you already have the sickle out of the mower (take it out if you don't) I would take out all the head bolts and completely redo the head end. That is the ONLY place the bolts are handy, otherwise I much prefer rivets.
No, I would'n buy their tool. But I do have a tool for rivets that don't work too bad to replace secctions in the machine.
third party image
mlm
07-04-2006 14:45:23
I use a small hydraulic jack with a hard nut welded on the top. the nut needs to have a larger ID then the bolt head OD. Set the jack on a wooden block under the section bolt then pump it to put some pressure right around the bolt head. Now you can get a solid hit with the punch. Also works good to put some pressure on the replacement bolt to help draw it in. Can tap on the socket to seat the bolt.
Works good for rivets too.
