PTO direction
Joe(TX)
07-04-2006 06:52:38
I ran across a post hole auger that requires that the pto rotate backward to normal.
What tractors had the backwards pto?
Joe(TX)
07-05-2006 09:39:28
 Re: PTO direction in reply to Joe(TX), 07-04-2006 06:52:38
Thanks for the input. The digger is going to be at action on the 15th of July.
Brendon
07-04-2006 15:16:12
The Kubota 6000 had a PTO that ran backwards compared to most everything else.
evielboweviel
07-04-2006 09:31:16
farmall cub
if it is a cub unit it will bring decent money from a collector
Ron
Dachshund
07-04-2006 09:13:52
Some Yanmar's did.
RodInNS
07-04-2006 07:11:45
Belarus..... We had a 520A that would spin backwards, but I think that was only if it was in reverse, and only if it was moving. Basically a ground drive PTO.... Normally, it turned the same direction as all the rest we have in the yard (blue). I don't know of any major NA tractors that had a reverse PTO as it's normal operation. What I do believe had this feature was the grey market Japanese stuff. I think you best look for another auger. This one sounds like an orphan.....
Rod
