Need books for IH 990 Mower-Conditioner
Willy P
07-01-2006 06:36:10
I just got a IH 990 Mower-Conditioner and I need to find a parts book and operators manual for it,not having much luck on ebay does anyone have a extra copy that they would like to sell? Are these good machines? It just needs a few bearings,belts and new sickle. How do they do on bermuda grass or do they do best on alfalfa? Thanks for any help.
Randy as in Randy-IA
07-02-2006 14:51:41
 Re: Need books for IH 990 Mower-Conditioner in reply to Willy P, 07-01-2006 06:36:10
Hi , You can order those books from the dealer as copies . They are also available at bin der bo oks . com . ( Take out all the spaces .)
I have a 990 and I like it but I don't have any other frame of reference . It's the only one I've ever owned and I've only had it a year . I had to put a couple bearings in the combination drive and all new tines on the reel , readjusted the reel and the roll gap and tension , rebuilt the chain tensioner , put new seals in the gearbox ( also put in new bearings there since it was open ) , all new guards and a new cutter bar that I haven't installed yet because the old one works good , reset the register of the cutter bar since it was almost a 1/4 of a section off and I still have some misc. welding to do on it . It's easy ( more or less ) to work on . Not all parts are still available but the more common wear parts are generally off the shelf , tine bar bushings from IH are expensive so I haven't done those yet . I think that for the price it's cheaper to rebuild one of these as good as possible than it is to buy a slightly newer model of anything else . I have less than $700 total in mine not counting my time ( a LOT of my time :-] ) . I cut timothy , brome and orchard grass mixed with a little alfalfa and so far so good . I cut at about 5 mph . I only cut 6 acres . Still working on the correct roll gap and tension for grass/mixed hay . The book say's about .020 , I have slightly more than that right now . It's just a sliver of light showing through the rolls but it's still to wide I think . It did OK on the first cutting this year but I think it could condition a little better . It didn't break the stems consistantly on the alfalfa . I'm going to crank the tension down a turn first of all before I do anything more to the gap . Which style do you have , rubber on rubber or rubber on steel for the rolls ? I've been told the rubber on rubber are better . I have the steel bottom roll . Good luck with it ! ...Randy
Seth_ia
07-05-2006 20:07:46
 Re: Need books for IH 990 Mower-Conditioner in reply to Randy as in Randy-IA, 07-02-2006 14:51:41
The sickle refered to above came from Herschel-adams. Much cheaper and pretty good quality. Randy, are you interested in that machine for parts?
Willy P
07-02-2006 19:37:41
Thanks for the info,I have the metel on top and rubber on the bottom. I have the gearbox apart now replacing the seals and the bearings and I don't understand what holds the collars on to the shaft that the seal goes around. I think that is what happened to this one, somebody replaced the seals and these collars slipped forward and the seals and the bearings slipped out and of course the preload on the bearings went bad. The gears have some wear on them but they will be alright. I hope that I explained this right about the collars. Do you have a parts book on your machine? If you do would you look up the number to the wide belt with the grooves on it that the gear box pulley drives? I need to find one. The other belts I can order locally. I don't have a good IH dealer close but I order from a dealer up north of here but I always give him the part number and he sends it to me. I may post the gear box over on the IH board and see if there is any experts that might help on that collar. Thanks
07-03-2006 10:10:12
 Re: Need books for IH 990 Mower-Conditioner in reply to Willy P, 07-02-2006 19:37:41
Hi Willy , The belt # is 540547R1 . That's the # on the belt from Case IH . I don't have a parts book but I do have a good dealer close by , two in fact . I have the unit repair manual and the operators manual . BTW I was remembering it upside down , I have the metal on top too . DUH! I must spend to much time under it ! Nothing holds the collars on the shaft but friction . If they are loose there is not much you can do except have new ones machined that are a few thousandths smaller than the shaft on their ID . Then they are heated up to expand them and the shaft could be frozen to contract it then the collar is slipped on and when everything warms/cools it's locked together . If they are loose then they've spun on the shaft maybe due to a bearing freezing up and getting HOT . You could try and tack weld them back on but that might warp the shaft if not done right . It shouldn't take much to hold them in position though . The pre load on those bearings is 7 to 15 inch lbs per shaft or 14 to 30 in lbs for the complete unit . I couldn't find a suitable click type torque wrench to check that so I used an old beam torque wrench and guessed a lot . Use a 1-15/16th socket and a 1/8th " allen wrench inserted between it and the splines on the shaft to check it . Do you have the service manual ? I guess I should've asked that before I started giving directions . But if you need more info I'll be glad to help out . Where are you located ? Good luck ...Randy
bshannon
07-02-2006 05:23:31
Sorry I dont have a book anymore, they were good machines in their time though, If you have a good sharp sickle and properly adjusted guards it shouldnt be a problem in grass. Good luck!
