NH 1409 and 1410 Discbines
Carp
06-28-2006 13:56:01
I have been wanting to get a discbine, but did not have the HP to run the 1411. Now that they have the 1409 and 1410, I was wondering if anyone has any experience with them. I have a 706 Farmall and was wondering how it would handle them. I have mostly bottom ground in SE Ohio. I would also be interested in information on other discbine makes.
Thanks for the info.
DAVID MCCULLOCH
06-30-2006 11:14:06
 Re: NH 1409 and 1410 Discbines in reply to Carp, 06-28-2006 13:56:01
I HAVE A NH 1410 THAT WAS NEW LAST YEAR.I JUST FINISHED PUTTING DOWN 5 ACRES OF FIRST CUTTING. I HAVE BEEN USING A 5640 WHICH IS 62 HP WHICH DOES A FINE JOB. TODAY I USED THE 4630 WHICH IS 52 HP AND THAT WORKED GOOD ALSO. WHEN I GOT IT THEY SAID I NEEDED 60 HP BUT I THINK A 45 HP TRACTOR WOULD RUN IT OK.
Carp
07-03-2006 11:34:41
 Re: NH 1409 and 1410 Discbines in reply to DAVID MCCULLOCH, 06-30-2006 11:14:06
Thanks.
Josh in PA
06-28-2006 18:01:56
I have an oliver 1655 (70hp) and borrowed a neighbors kuhn fc300. I think its 9'6". It pulled it ok, but in tough hay I think it would work it pretty hard. I think a new discbine is $15k or better, maybe a used discbine and used 100+hp tractor would make sense.
Josh
Carp
06-29-2006 08:12:24
 Re: NH 1409 and 1410 Discbines in reply to Josh in PA, 06-28-2006 18:01:56
I don't have a 100 hp tractor, or really the use for one.
TN Ford Farmer
06-30-2006 04:48:17
 Re: NH 1409 and 1410 Discbines in reply to Carp, 06-29-2006 08:12:24
What hp is your 706? I have a 1411 that I am pulling with a 8000 (105 pto hp). I think if you kept the blades sharp and slowed your ground speed you could pull a 1411. Minimum hp requirements on the 1411 are 80. The thickness of the hay doesn't seem to make any difference in the way it pulls the tractor.
