Door looks on a 2006 Impala
Rusty Scupper
06-28-2006 11:34:28
Is there anyway to disable the locks from locking when you take the car out of park and vice versa when you stop you have to either put it in park or hit the door unlock button.
Thanks
Joe (Wa)
06-28-2006 22:11:49
 Re: Door looks on a 2006 Impala in reply to Rusty Scupper, 06-28-2006 11:34:28
This works on my 2003 K2500HD. Have only done the disable, haven't checked out the other features.
Beginning with the ignition in the LOCK position. Pull the turn signal/multifunction lever all the way toward you and hold it there. Turn the ignition to the RUN position and then to the LOCK position twice. With the ignition in LOCK, release the multifunction lever. The doors lock and then unlock to signal entry into program mode.
Select one of the following options for the automatic door lock.
* To disable the automatic door lock feature and the automatic door unlock feature, press any door lock switch twice.
* To enable the automatic door lock feature but disable the automatic door unlock feature, press any door lock switch once and then press any door unlock switch three times.
* To enable the automatic door lock feature and the driver side door unlock option, press any door lock switch once and then press any door unlock switch once.
* To enable the automatic door lock feature and the all door unlock option, press any door lock switch once and then press any door unlock switch twice.
Exit Programming by turning the ignition switch to RUN or wait until 10 seconds elapse with no input to the lock switches.
Ultradog MN
06-29-2006 05:50:17
 Re: Door looks on a 2006 Impala in reply to Joe (Wa), 06-28-2006 22:11:49
Yeah,
I didn't like that function on my 02 2500 HD either when I got it and this is the way I disabled it.
It was written up in the owners manual somewhere.
Had mine to the dealer yesterday - had a tire out of balance so had them all re balanced, rotated and an oil change. (got a $25 off coupon in the mail so I used it)
Came Real close to pulling the trigger on an 06.
Mine has 125K on it now so am thinking... Going to talk to the tax lady today and see if I need the deduction.
Chevy has a real good incentive on right now.
0% interest for 6 years. promotion lasts till 7/7
MN Bob
06-28-2006 15:53:44
My wifes new Buick is like that, as soon as she starts the car everything locks up untill the button is pushed. It is a proggramable feature in the car. My key (number 2) allows all the doors to stay unlocked and all doors unlock when I use the remote. (my choice) Hers only unlocks the drivers door. Her Choice. You would think we lived in a high crime area instead of rural MN.
Rusty Scupper
06-28-2006 15:59:01
 Re: Door looks on a 2006 Impala in reply to MN Bob, 06-28-2006 15:53:44
MNBOB,
So when you use key #2 and put it in drive do the car doors lock? How about when you go over 30 mph and then stop but still in drive are the doors still locked?
I don't see where this can be changed in the "Driver Information Center". There are options but nothing to handle the above situation.
Maark
06-28-2006 11:56:30
Look in your owners manual. My manual for my 2000 silverado told me different ways that the doors could be programmed to lock.
Rusty Scupper
06-28-2006 15:34:58
 Re: Door looks on a 2006 Impala in reply to Maark, 06-28-2006 11:56:30
I looked in the manual but there isn"t an option for that. I thought that there was some "undocumented" proceedure to disable the "rolling lock" feature.
