Kuhn GF440 tedder - retiminging a basket
Ken Macfarlane
06-28-2006 09:17:47
Hello, my old message dropped off without a solution. On a kuhn tedder, to retime it, do you knock the top most rollpin out of the mainshaft that the tines and wheel are attached to and drop the works an inch or two or do you unbolt the driveshaft housing and attempt to pull it out to retime?
Thanks.
Harold Hubbard
06-28-2006 15:32:46
 Re: Kuhn GF440 tedder - retiminging a basket in reply to Ken Macfarlane, 06-28-2006 09:17:47
Yes. Drive the roll pin out and drop the rotor enough to slip the gears by until the teeth will past each other without hitting. Hold one rotor and pull the next one back and forth aginst the gears to be sure you have it right. Use new roll pins to reassemble it, or you will be doing it again out in the middle of a hayfield somewhere. When I used a Kuhn, I would replace all of the roll pins every year before I started haying. The pins are doubled, a small one is driven through the center of the large one, your dealer should have the proper sizes.
