Vermeer Gate tip
redmt
06-28-2006 05:27:59
This works on a 505i not sure about others. If for some reason you want to work on the belts you can slack them with out a comealong. If you have the long red safety bars cut one of them in half and drill new holes. Raise the gate up, put the bars in and then chain up the 2 rollers. Slowly lower the gate onto the bars. The belts will be loose. Works great for me. Also as long as the springs are streched out clean the oily chaff out of the spring behind the door. You will know if it is dirty cause it wont be straight. You will make better bales.
