NH S66 Baler Question
Jimbo in MT
06-25-2006 11:12:36
I"ve got a NH S66 baler that has a Wisconsin motor on it, which doesn"t run very well, i"m looking to make it into a PTO driven type. The tractor that I have is a Ford 630 with about 48HP. Would this be sufficient to run the baler off of, or do I need to get the motor going?
Thanks in Advance Jimbo in MT
Leroy
06-26-2006 16:36:52
 Re: NH S66 Baler Question in reply to Jimbo in MT, 06-25-2006 11:12:36
I have heard of 640, 650, and 660 ford tractors but never a 630, what year is it? if it is a 600 series with 4 speed then it is a 640 and low gear is too fast for a lot of conditions, a 650 is a 5 speed with a lower low speed but no LPTO, now a 660 has the 5 speed and live pto. Would it be one of the newer compact tractors? And what is the problem with the engine?
RodInNS
06-25-2006 18:41:21
48 hp would be a big expectation from a Ford 630. Low 30's would be more realistic from a 600 series Ford, unless somebody changed it to a 172 cid engine from an 800 series, then it would get toward mid 40's on the PTO. That said, power shouldn't be a very limiting factor in running the baler. The lack of Live PTO would be a far bigger concern to me. That could make a difficult job into a very tedious job. Personally, I'd want to fix up the baler engine if that's the tractor I had to work with. HTH.
Rod
farmerblew
06-25-2006 15:14:16
IRun my NH66with a 30hp kubuta and my ford jubilee with no problem other than they rock with the plunger cycle pretty good!
Wisbaker
06-25-2006 11:45:42
When I was a Kid we ran our Super 66 pto baler with a Farmall H (27HP)It seemed to do fine, how ever once we got a Super M I got used to more power. Once or twice I ran a 24T John Deere baler with the H, but you had to take it slow and the tractor would run against the governer stop
Rexalot
06-26-2006 05:37:07
 Re: NH S66 Baler Question in reply to Wisbaker, 06-25-2006 11:45:42
I used my Farmall H to cut and bale with for a couple of seasons. I cut with a NH469 and baled with a NH S67. It did the job ok, although I always felt that I needed more RPM to get that baler singing.
I have since traded up to an Oliver 1800.
You should have no trouble pulling on flat land. Just may need to take things slow.
