brush hog for 1650 Oliver
Rich Iowa
06-22-2006 19:43:10
I have an Oliver 1650 that's is good shape power wise, 65+ hp. I've been thinking how handy having a brush hog would be, keeping my dad's place cleared and maybe doing a few side jobs. What sort of things should I look for in a mower? how big of a mower can my tractor handle? Which is better, pull-type or 3pt mounted? What kind of price range would I looking at? In college, I helped build 15ft Woods mowers, sure do like them but I don't have the power or money for those. I've seen the mowers at the farm stores, seem way to light duty to me. Thans for any opinions/ advise you can share.
bvomark
06-26-2006 07:46:22
 Re: brush hog for 1650 Oliver in reply to Rich Iowa, 06-22-2006 19:43:10
I have a Massey 471 that is about 70 hp with a 64 hp rating at the pto. I have been pulling a JD 1518 batwing. It is a 15 foot cut. Depending on what is being cut I can run in 5th gear (8 fwd speeds). The gear I have to use depends on the thickness of the weeds being cut and also the height that you are cutting it. I have been cutting small trees that is about 2" in diameter mixed in with the weeds. These trees are not a problem as long as you don't hit 4 or 5 at once.
If the grass is too thick all I do is slow down a gear or 2. I can still cover more ground going slow than I could with an 8 ft or even a 10 ft mower.
I also called prior to purchase and the 15 footer required a minimum 60 hp.
Rich Iowa
06-25-2006 17:57:55
Thanks for the helps guys. The mower would mostly be used to keep open grassy areas cleared, I would guess the largest I'd be cutting would be 1 inch, possibly 2 inch in diameter. I will keep my eyes open for something in the 8-10ft range.
AB- yeah, I'm slowly working on getting the parts as the money comes in and I have time to work on the beast. Couple weeks back I installed the new battery and cables. I was very happy with the results, first time I have been able to start the 1650 w/o the aid of ether, took a couple cycles of using the preheater, but it started. Thanks again everyone for the advise.
evielboweviel
06-23-2006 19:35:54
10' pull type or 8' 3pt
Ron
Terry in Alabama
06-23-2006 10:44:07
Rich,
I agree with the previous posts.
I have an Oliver 1655 with an 8' Bush Hog brand, 3pt mounted cutter. I have had it for 6 years and I like it very much. When I was shopping for cutters, I looked at Bush Hog and Woods. Both are very high quality, but the Bush Hog is more rugged and sometimes I cut some small brush with it. However, the Woods will do a prettier job if you are just clipping pastures or light hay fields. Also, if you are just clipping pasture weeds, the light duty cutters at the farm stores will last a long time.
I bought the 3pt unit for manueverability in fence corners and around trees.
Like the previous post said, the size of the cutter depends on what you are cutting. My 1655 just plays with the 8 footer clipping pastures, but I have also cut some grown up fields for my neighbors that had grass/weeds 3 to 4 feet tall and it gave the 1655 all it could handle.
AB
06-22-2006 22:42:24
Get a mower that"s wider than your tractor tires to avoid leaving strips where your tires beat down the grass. How heavy a mower you need depends on what your mowing. Always check gear boxes on used mowers. Did you find the parts you asked about a while back?
Jerry (AL)
06-22-2006 20:05:57
I have 54 HP and a 6 foot King Cutter bush hog but I sort of wish it was 7 foot. A lot depends on what you plan on cutting. Heavy Brush? clipping pastures? It makes a difference. Mine is a medium duty but I only cut weeds and pastures.
I also didn't want to get into anything with dual spindles on it for cost reasons.
A neighbor had a great looking heavy duty bush hog for sale , a Rhino. That was a good solid machine with heavy skids but a little too much for my tractor at 8 foot.
