NH 273 pickup doesn't turn
db120
06-22-2006 06:07:08
Hello all. I just purchased a 273 at auction. It hasn't baled in several years, but has had little use. The pickup doesn't turn. The clutch is engaged, and all chains are in place. There is a cast piece behind the drive sproket that doesn't turn when the baler is running. When you put a pipe wrench on that cast piece, you can make the pickup turn. There seems to be some disconnect between the drive sproket and this cast housing. What's wrong here? Thanks, -DB
Steve from New Holland
06-22-2006 09:51:29
 Re: NH 273 pickup doesn't turn in reply to db120, 06-22-2006 06:07:08
That is an over-running clutch mechanism. There are 2 spring loaded pins in the inside cast piece that are supposed to push out into grooves in the outer sprocket. The pins are obviously stuck in. You can take a hammer and beat on the inner cast piece and hope they come out. However, over the years I have not been very successful doing this. Be prepared to remove sprocket to get to the pins. Remember, LOTS of pentatrating lube. Steve
K in Canada
06-22-2006 10:00:40
 Re: NH 273 pickup doesn't turn in reply to Steve from New Holland, 06-22-2006 09:51:29
On the 273 can they handle plastic twine or am I stuck with Sissle?
db120
06-23-2006 09:11:25
 Re: NH 273 pickup doesn't turn in reply to K in Canada, 06-22-2006 10:00:40
Thanks. I see what you are talking about with the spring loaded pins, and will pull that apart today.
Also, yes the 273 will handle non-sissal twine. I bought the better (heavier?) version at New Holland, and started using it sucessfully with no adjustment whatsoever. Thanks -DB
