I would just look it over and make sure its complete with nothing damaged or missing that will hinder its operation. Things that can break: needles, tine bar feeder forks, and pick up teeth. It is used, so before running it I would check that everything is in "time", the knotters, plunger, and feeder tines. I would also make sure none of the springs are missing or broken for the plunger stop (make sure this is free and pivots), hinged feeder tine forks, and the one on the knotter group. There are additional springs on the "haydogs" that get weak or break with age. Expect to replace a few pick-up teeth. Grease it up, check the gearbox oil (if it's anything like a 68 there are two gearboxes) sharpen the edge on the plunger knife it it needs it and then go baling! I keep a handful of spare shear bolts, there are two sizes, one for the knotter and one for the flywheel/plunger. I also have a few repair links for the chains in the tool box on the baler. Seems like when there is no spare that is what breaks.
