NH 315 Hayliner
masseybob
06-21-2006 16:46:57
I"ve got a NH 315 with a 70 thrower on it. It will bale 5-6 bales good, and then a busted one.You can see the burn marks on the plastic twine on the bottom of the bales. Any info would be appreciated.
Steve from New Holland
06-22-2006 09:54:32
 Re: NH 315 Hayliner in reply to masseybob, 06-21-2006 16:46:57
Plastic twine is susceptable to burning on the thrower belts. If the thrower is in top shape, they generally work ok. Sisal twine should help this. Steve
Greg In Pa
06-21-2006 19:26:58
I had the same thing kinda on my MF #12 baler i got. As i watched it when baling I noticed that if i go fast enough it wouldn"t burn or tear. If the windrow was light and didn"t push the bale fast enough it would burn or rip the poly twine. I went to sisal and it didn"t seem to break anymore. Hope this helps????
