new holland wire baler
ohiofarmallfarmer
06-19-2006 17:45:02
i have a NH 68 superhayliner wire tie baler. it misses on the outside( flywheel side) twister. it very spuratic when it misses, u never know when or where. but out of 625 bales i made saturday it missed 50 or so. when it misses a bale it doubles the wire on the top of the bale from the knot untill it ties again and then is usually fine. whenever it misses a bale it though.. it always doubles the wire on the next bale. any ideas??
ohiofarmallfarmer
06-20-2006 20:29:54
 Re: new holland wire baler in reply to ohiofarmallfarmer, 06-19-2006 17:45:02
well to answer your question..the bales are not even..this side of the bale tends to be about 1 - 1 1/2 inch shorter than the other side. its not really tighter.. just shorter.
Joe(TX)
06-20-2006 05:17:45
I sounds like the twist is hanging in the twister hook. Make sure they are not too deeply grooved or not advanced too far as Tx Jim mentioned. Are the bales comming out even on both sides? If the outside is tighter it will make the problem worse.
Tx Jim
06-20-2006 04:01:16
Back the point of twister hook 1 to 2 teeth ccw. This will help wire come out of hook after tie is made. This works on a JD baler so I think it will work on a NH. Tx Jim
BobMo
06-19-2006 19:30:29
Farmer, check your manuals twister service chart. I think you'll find the answer and the fix there. 50 or so missed out of 625 isn't "spuratic" that's a problem and a headache. Good luck..... .....
