John Deere 14T Baler
oldnnew
06-19-2006 09:29:04
I was baling hay yesterday and completed 4 bales and then, BAM, broke off both needles. I have yet to diagnose the problem, but what I really need to know is where can I get needles cheap? I know at the dealer they are $100+ each. Are there any good places for used baler parts? Any help would be great! Thanks!
tim[in]
06-20-2006 00:15:07
 Re: John Deere 14T Baler in reply to oldnnew, 06-19-2006 09:29:04
like the others said about the stop spring. also check ebay for 14t needles. at least one is on there now.
Dean in iowa
06-19-2006 19:30:19
I have a set of needles for your baler. Reasonably priced. Contact me.
430WLPG
06-19-2006 18:35:31
I have a used set I'll take $100.00EA. for them PLUS SHIPPING. Check with John Deere first
meadova
06-19-2006 14:32:13
Need to retime the whole machine. adjust the tripdog and make a brake adjustment. Just a suggestion. also its a lot easier to run the machine through cycles by turning the flywheel than buying needles at least till you figure out the problem. you can speed the tie process by pulling up on the tripdog when running by hand.
old
06-19-2006 10:03:25
One of your problems is the safty stop for the pluger isn't working, probably a broken spring. I have a set of needles but I have to have out ot them what I payed for them and I payed $100 each for used ones. Last time I checked at JD needles where something like $200 each or more but thats been years ago
oldnnew
06-21-2006 09:09:38
 Re: John Deere 14T Baler in reply to old, 06-19-2006 10:03:25
Yep, you were correct about the stopper. I checked the baler out last night and the stopper was in working condition, except there was a piece of stick wedged between the stopper and frame not allowing it to come up into the chute. Just a simple piece of wood cost me a lot of time and money!
old
06-21-2006 09:16:09
 Re: John Deere 14T Baler in reply to oldnnew, 06-21-2006 09:09:38
Yep I have scraped out one 14T because of that type of problem. The one I had/have the stop wasn't working, then the plnger hit the needles and the needles broke the knotters and at that point it just plain wasn't worth fixing since I knew where there was another 14T for $350 and the part to fix the one I had would have cost over $700
