Vermeer 605C
c simpson
06-19-2006 03:59:21
The belts on my 605C (It has been updated w/5 10" belts) are running towards the right and rubbing on the belt guides in the rear. Any ideas?
504 Baler Guy
06-19-2006 15:46:55
 Re: Vermeer 605C in reply to c simpson, 06-19-2006 03:59:21
The front braces that come down from the middle of the baler to the hitch are adjustable. You can use them to tiwst the frame and adjust the tracking. Only adjust if the belts track to the right with a level bale in the chamber. Push the right side back and pull the left to the front.
Redmt
06-19-2006 14:22:24
You probably have a bearing out in one of the rollers. That will cause your problem.
Jimmy King
06-19-2006 04:55:37
Bent tail gate, I don't remember that much about a C I jumped from the A to the F. Are there two turn buckels in front if so try adjusting them. I would check the tail gate first.
csimpson
06-19-2006 05:35:04
 Re: Vermeer 605C in reply to Jimmy King, 06-19-2006 04:55:37
The tailgate is not bent.
