I have both a S67 (same as your 67 except draw bar and plunger rides on roller bearings instead of wood) and a model 68. It took me about 1200 bales over the last six seasons to figure out how to make a good bale. First, you need a good sized windrow. I use a NH469 haybine (9ft swath). Depending on the size of the windrow after raking I may rake two rows into one and have done three into one before. Ideally, you"d want atleast 24" to 36" inch round windrow. Size does matter here. Second, Bale chamber tension will affect shape.(Setting tension using the same spring dimension or number of turns on the handles is fine to set weight initially.) After the first few bales you need to tightend down the tension spring on the bale chamber for the side that the bale is long and loosen the side that it is short until the bales square up. Then adjust again for weight. Make a few turns on each at a time. Experiment. You will be able to see the change in bale shape almost immediately. Third, limit your bale length to no more than 3 or 3 1/2 feet. (I tend to stay about 3 feet) Thin material feed can cause "long bales" even though you have set the length. In thin material you should increase your ground speed to help fill the chamber. Bales will also get "out of square" in thin material due to feeding issues. I also have two sets of wedges. If none of the above suggestions improve your bale shape you can also adjust your tine bar forks to either put more or less material into the left side of the bale chamber depending on the long side of your bale. In my S67 baler I have the adjustable tines set as follows: Left set, 3 inches from the end of the square tube(as viewed from rear of baler)and the center tine forks approx 15 inches from left side as measured from the end of the square tube. (If your baler has had alot of use and still has the OEM forks you might compare them to a new set. Mine were worn down almost a full inch!) In my 68 baler I have 3 sets of adjustable tine forks equally spaced. I added a pair before I figured out the "secret of bale chamber tension" thinking it was feeder problems. Post up if you get "squared away!"
