Multi-diameter Disc Harrow Blades
Land Owner
06-18-2006 03:07:01
I purchased a used Ford I80I disc harrow and find that it has two different diameters blades. The front gang are 22" and the rear are 20". Why? Is this someone's mistake? I am replacing bearings and probably the 22" blades.
hayray
06-18-2006 18:29:37
 Re: Multi-diameter Disc Harrow Blades in reply to Land Owner, 06-18-2006 03:07:01
When I replace mine I buy new ones for the front and move the good fronts back to the rear. Cost my about a thousand dollars last time for brand new 22 inch front blades.
Coloken
06-18-2006 07:28:07
The front ones have probably been replaced and the back one not. A common thing.
Keith T
06-18-2006 03:33:10
Front disc blades wear down about 20 to 30% faster than the rear blades as they are the ones doing the primary cut and the rear blades are working loose dirt . It is common practice to ,and a lot of work ,move the front blades to the back and the back ones to the front . I'd use it as is. Someone has done the hard work for you.
