Best wood for spreader floor
Dave from MN
06-17-2006 17:57:53
Well digging in to this here New Idea #217, what would you all say would be the best wood for the floor replacement. #/4" tongue and groove-green treated. Pine, Oak, fir?
atgreene
06-28-2006 17:16:58
 Re: Best wood for spreader floor in reply to Dave from MN, 06-17-2006 17:57:53
What size tires does your New Idea have? Mine has old 10.00 20 truck tires but they rub on the gate mechanism. I"m hearing differing things on what tire size I should have but would like to go back to original.
atgreene
06-25-2006 18:37:02
I'm also redoing a 217 and am looking at the trex decking. I've seen other new manure spreaders with it and it seems like the stuff to use.
jossette
06-19-2006 20:16:14
third party image
White oak tongue and groove..
tg in VA
06-19-2006 08:37:15
I use 1" (actually 3/4") southern yellow pine. Plain, planed lumber, no tongue and groove ( I use 1 x 6"s and rip the last one to fit, I install the boards with no gap). Once installed, I paint it with burned motor oil. The last one I did (about 10 years ago) is sitting in the woods with the floor in tact.
Rod in Smiths Falls, ON,
06-18-2006 14:22:18
I'd never done one before but last fall I used white oak planed to 1", tongue and grooved, fastened with carriage bolts and soaked in old engine oil. I wanted a floor durable enough to handle occasional loads of firewood and sharp impacts from thrown blocks.
So far I've only used it for manure, and it works fine, with no undue swelling or shrinkage.
Chris(WA)
06-18-2006 05:45:08
I wonder how the plastic decking like Trek would work? I like the looks of that plastic one piece stuff the other guys are talking about. Probably the most practical way to go.
paul
06-19-2006 00:31:44
 Re: Best wood for spreader floor in reply to Chris(WA), 06-18-2006 05:45:08
Decking likes to crack under a sharp load, like a rock or ice chunk. Needs more support under it than wood, closer spacing of cross members....
--->Paul
jim ball
06-17-2006 18:47:39
i use marine plywood and cover with plastic from
farmtek. use liquid nails & plastic screws to adhere plastic to wood. also some metal carriage bolts.
Cliff Neubauer
06-17-2006 19:26:02
 Re: Best wood for spreader floor in reply to jim ball, 06-17-2006 18:47:39
We used the treated plywood and plastic sheeting on our's last winter. We have a local place here that sells the plastic and we use quite a bit of it. For something like a spreader or silage wagon floor the plastic is great and it's pretty easy to work with.
phillip d
06-17-2006 18:29:19
do you have any juniper?will last probbably longer than most spreaders.phill
