NH 269
max adams
06-17-2006 04:41:08
Can anyone tell me good and bad points about this baler? Any certain thing to watch for? As always thanks! Max
chick
07-08-2006 22:38:01
 Re: NH 269 in reply to max adams, 06-17-2006 04:41:08
Also, if you will call New Holland's tech publication dept, you can get a copy of a video of how to adjust the knotters and common mistie problems, for about $25. Well worth the price. Actually NH made 2 of these VHS tapes, but they only have the newer one in stock now. I have both of them, and they have basically the same information. Just wish it was on DVD. Don't understand why NH doesn't put this video on DVD.
Chick
07-08-2006 22:35:11
I use a NH 269. I have made several modifications to it. The main trouble I had was banana bales. The 269 has 3 hay dogs on to, but only 2 on bottom. I had to cut a hole in the bottom of the chamber, being careful to make sure it would line up on the plunger in the correct position so that I could cut out a spot on the plunger, so that it would pass over the hay dog. It is not too big of a job, but you just have to pay attention to what you are doing. I also made the wedges larger on that side of the bale chamber. After doing all this, and adjusting the bale tension, I am able to get square bales out of the machine. This machine is not one of the sought after balers, but I have managed to make this one work right.
hay master
06-19-2006 14:13:00
Max,
I had one for 3 years. It worked great until the feeder mechanism blew apart. Don't run it too fast, around 66 strokes per minute. The chute did clog from time to time. Got to clean the chaff out alot. I now have a 269 for parts if your interested, NW Ohio
