NH 311 Needle Safety Latch Adjustment
FrenzFarms
06-16-2006 20:35:05
It has not been a good day. But lets just say I have two brand new twine needles on my baler now. (Failure to reset needle yoke after fixing a sheer bolt and by-passing latch. Nuff said.)
NH service tech came out and replaced the needles and retimed the knotters.
New issue: Breaking sheer bolts at random, but extremely frequent times. Once every three to ten bales. I believe this is related to the needle safety latch being out of adjustment.
The sheer bolt is only breaking when the knotter trips and literally as soon as it releases *any* tention on the safety latch cable. This makes me think that the latch is engaging too soon. However, its not doing it every single bale so its rather confusing.
I am open to suggestions here. Again, the knotters are in time.
John e.c.MI
06-18-2006 05:22:39
 Re: NH 311 Needle Safety Latch Adjustment in reply to FrenzFarms, 06-16-2006 20:35:05
Had the same problem with my 311 this year(minus buying a set of needles). Would randomally break shear pins right after the knotters tied. I suspected the cable from the needels to the safety latch may have streached a little so I adjusted the turnbuckle just a little. Also found a greese zerk on the pin that the safety latch pivots on that I never knew was under there so I gave that a little greese. No problems after that.
paul
06-16-2006 21:58:50
I had a similar problem with my 270. A very small - tiny - adjustment to the safety latch arm - back by the needles - cured it.
Not saying that will help you out or is the right thing to do. But after 10 shear bolts, I had to do something out in the field a couple years ago.... Do too much & of course you lose the protection of the latch, and yet another set of needles...
--->Paul
Shovelman
06-17-2006 18:08:04
 Re: NH 311 Needle Safety Latch Adjustment in reply to paul, 06-16-2006 21:58:50
I had a similar problem with my 270 where the plunger would make contact with the safety latch when knotting, but only enough where it would make a "bang" at the end of the tying cycle, but not enough to stop the plunger or shear the shearbolt.
I checked and rechecked the timing and latch adjustments which were all within spec., but what finally cured it was setting the knotter timing a tad earlier, so the needles and latch would be "home" by the time the plunger came back around.
It bales like a dream now and will hog through big windrows better than our JD 336, which is pretty impressive for such a little baler.
As Paul stated, a very small adjustment can make quite a difference with the latch on the 270, the 311 may be as touchy. Just be sure it is adjusted properly to avoid an encore performance!
Good luck,
Scott
Shovelman
06-17-2006 18:22:09
 Re: NH 311 Needle Safety Latch Adjustment in reply to Shovelman, 06-17-2006 18:08:04
PS:
Check the knotter brake as well. They sometimes get greasy and will allow the knotters to slip from their "home" position, thus engaging the safety latch and breaking the shearbolt.
Scott
BigMarv1085
06-18-2006 14:12:51
 Re: NH 311 Needle Safety Latch Adjustment in reply to Shovelman, 06-17-2006 18:22:09
I bought my 311 brand new in 1988. The only problem I've had was once the chain on the outside kept coming off. After the 4th time, I oiled it really well and it stop. It would typically break about 7 bales per 1000. I bought a 5 gallon bucket of amsoil high temp grease and started using it only the baler. The only time it will break a bale is if you get a wet clump or where you tie the bundles of twine together.
