haybine-baler size
Tom 8N396936
06-16-2006 10:29:16
I keep hearing everyone talk about good size windrows for the baler. Well it seems to me the rows will be what the rows will be- a lot of hay will make a large wind row right? Should I have taken into consideration the size of my baler when picking my haybine? Also I bale in first gear - is this too slow? thanks
tom
Don-Wi
06-17-2006 08:26:00
 Re: haybine-baler size in reply to Tom 8N396936, 06-16-2006 10:29:16
Like Old said, it helps to know what model baler and possibly the tractor. We pull a Massey 12 behind our 285, and we go in 2nd in heavy hay, 3rd in light. 1st gear does sound a little slow to me, but I don't know what you've got.
Donovan from Wisconsin
TimS
06-16-2006 11:00:34
A lot of folks will rake windrows together so they don't have to make as many passes with the baler. To big to me is when I can't drive slow enough to keep the shear bolts from breaking.
What baler and tractor are you using? If it is a square baler and the bales are coming out banana shaped, sometimes that can be caused by either to small a windrow or to slow feeding of a windrow....
old
06-16-2006 11:00:18
Really need more info on what type of baler. I use a NH 460 haybine which doesn't put it in windrows, and a NH850 baler. If I use 1st gear I get bales that weight around 2500lbs which are just plain to heavy. I use 3rd gear and pull it with a 1955 Oliver Super 88 and the bales still are around 1800-2000lbs. Now when we use the JD-14T square baler we use 1st gear and I will be pulling it with an Oliver 77.
Tom 8N396936
06-19-2006 05:45:10
 Re: haybine-baler size in reply to old, 06-16-2006 11:00:18
Using a Farmall 656 pulling a NH 469 haybine. After that same tractor with a NH 273 baler. Use the 8N to tedd and rake. Never considered the rows were too light and that may be hurting the bale shape? tom
old
06-19-2006 09:04:08
 Re: haybine-baler size in reply to Tom 8N396936, 06-19-2006 05:45:10
Yep to light or to heavy either can hurt the way the baler works. I'm guessing its a squrae baler since that number isn't one I know as far as being a round baler. I know when you use a round baler you need to weave side to side one the winrows but you don't need to do that with a square baler.
Bullfiddler
06-16-2006 10:59:59
You can always rake two swaths together if the downed crop is too thin to make a nice tight bale.
