nh461 haybine - Kelly C
bigslick up nor
06-16-2006 09:37:05
Looking for the knowledgeable Kelly C
Do you have picture of the gearbox end shaft side where the bearing, cap & retainer is on?
Which side does the bearing sit?
I need to see to confirm this for assembly.
I am nearing the completion of reassembly of the belt replacement as well as a few more things during disassembly.
Thank you again in advance for your help.
Kelly C
06-16-2006 18:54:12
 Re: nh461 haybine - Kelly C in reply to bigslick up north, 06-16-2006 09:37:05
Here you go.
third party image
third party image
Hope this one came out ok. I just took a photo of my users manual.
bigslick up north
06-19-2006 09:22:14
 Re: nh461 haybine - Kelly C in reply to Kelly C, 06-16-2006 18:54:12
thanks kelly
In my removal process with this outer bearing being stuck, I had broke the flange. I had it welded to save hopefully nearly $300 part. But, in looking at the flange it is certainly shaped to for a bearing to fit inside, however, the bearing does not fit in. Do I need grind some inside material off to slip in or do I press into and hopefully not break?
Any advice is greatly appreciated and thanks again.
