NH Super 69 baler
Jim in WI
06-15-2006 19:12:44
Rebuilt knotters, I threaded new twine and then run a cycle thru, discard scrap piece off the knotter and then I ran a bale thru, one side tied normal and the other side tied both twine from the needle to the knot and wrapped twine around the knotter left twine outside of the needle. Why is it coming out of the needle?
jwn
06-15-2006 19:33:42
 Re: NH Super 69 baler in reply to Jim in WI, 06-15-2006 19:12:44
the reasen for that is because the twine is slipping through the disd on the knotter. to correct this you need to put in a new twine finger. or check the twine finger retainer spring to see if it is broken or weak.this twine finger fits down between the twine disc.is held in by a rivet and can be replaced with out disambleing knotter.check tension on twine finger spring can tighten retainer bolt and some times correct this.
Jim in WI
06-15-2006 19:53:37
 Re: NH Super 69 baler in reply to jwn, 06-15-2006 19:33:42
Thanks, I will give that a try.
