old cylinder leak
farmallbee
06-15-2006 18:15:07
just found a leak on my round baler cylinder-same as yours the gate wants to creep up. How much was the rebuild kit and can you do it yourself?
Thanks
old
06-15-2006 18:53:59
 Re: old cylinder leak in reply to farmallbee, 06-15-2006 18:15:07
Cost about $15-20 for the kit. I had to call the dealer to learn the trick to taking it apart and the lock ring was a bear to get out and if you don't know the trick you will not get it out. Feel free to e-mail me with questions. I don't know for sure that its fixed since I haven't done any more baleing at this time but will be doing some next week.
farmallbee
06-16-2006 02:05:59
 Re: old cylinder leak in reply to old, 06-15-2006 18:53:59
thanks a million. I will contact you if I need more advice.
old
06-16-2006 06:00:10
 Re: old cylinder leak in reply to farmallbee, 06-16-2006 02:05:59
I only rebuilt one cylinder on my baler because that was all I could do. The dealer only hjad one kit on hand. The way I found which cylinder it was, was to open up the hatch and then one at a time took off the hyd hose that would be for cloesing it back up and watched for fluid to keep comeing out of it. And sure enough that was the cylinder with the bad O-ring on it.
