NEW HOLLAND HAYBINE 489 Wobble Box?????
Ponchobro
06-15-2006 02:56:24
Hello, I have a 489 wobble box that was taken apart without indexing the flywheel. What is the correct way to get everything in time??? Thanks for your input!!!
Steve from New Holland
06-15-2006 04:22:24
 Re: NEW HOLLAND HAYBINE 489 Wobble Box????? in reply to Ponchobro, 06-15-2006 02:56:24
The flywheel does not need to be timed. The cast wobble arm on the output shaft that makes the knife go back and forth does need to be timed. The arm needs to be straight front when the wobble box is ni the center of it's stroke. Steve
Ponchobro
06-15-2006 12:56:41
 Re: NEW HOLLAND HAYBINE 489 Wobble Box????? in reply to Steve from New Holland, 06-15-2006 04:22:24
Thanks for the info. I have a question about the + MARKERS ON THE FLYWHEEL AND THE GEAR BOX DO THEY NEED TO BE ALINED WHEN THE SHAFT IS ANY PARTICULAR POSITION??? THANKS AGAIN!!!!!
