New Tahrs
Michael Soldan
06-14-2006 18:35:11
Got rid of a lot of problems this morning, had GOOD YEAR WRANGLERS on, truck bounced, vibrated and pulled to the left. The fronts were like new but there were wires stiking out of the sidewall. I paid $180 per tire for the fronts replacing the originals.I balanced them twice thinking that was the problem, dealer made the decision to replace the fronts with these two more Wranglers. I had terrible luck with these tires, I do not drive fast, never have much of anything on the truck for load, drive back and forth to the farm on paved roads. Welp I put on COOPER DISCOVERERS and went up one size to 245/75/16 from 235/75/16. Truck rode as quiet and smooth, no vibration or pull. I wonder what those Good Years cost me in wasted fuel? Anyway, I am happy with these new Coopers, like a new truck again. Ask me if I will ever buy a Good Year again! Mike in Exeter Ontario
Rick Kr
06-15-2006 19:18:30
 Re: New Tahrs in reply to Michael Soldan, 06-14-2006 18:35:11
Ron in MO stated a good point.
Tires when shipped to the OEM (GM, Ford, etc) from the tire manufacturers are sorted for "Road Force Variation" and some other key characteristics.
Road Force is a tangential force, but think of it as an out of round tire. The higher the road force the more vibration and shake you will feel in your vehicle, typically at the steering wheel or in the seat (butt shake).
Well you can guess that if the tire is out of spec that Goodyear and others do not scrap the tires, they get shipped. Where to? Aftermarket stores, Goodyear owned stores, dealers for replacements.
That is why you can go to the dealer and they may replace tires, and when you leave your car shakes more, you actually got worse tires from the aftermarket then what you started with.
And, Goodyear is not the only company that does this. I have seen all the tire manufacturers doing this.
The sad thing is, it can really be a crap shoot when you put new tires on.
Sorry for the long comments, but I spend a lot of time at work fighting with tire manufacturers to send good tires.
Rick
RodInNS
06-15-2006 11:52:46
I'm wondering if there isn't some major differences in tire brands in different localities. In my experience, I would say that the GoodYear wrangler is junk. I've not seen too many tires that wore as poorly as the set I had on a Ranger. They also had broken belts and shook like a bugger. On the otherhand, some of the very best tires I've had were GoodYear UltraGrip NHV's. The best snow tire I ever had, although they probably wern't the longest wearing. Can't say much good about Firestone passenger tires. Michelin has always been good, but expensive in my experience.
On the Ag side, I would say Firestone makes one of the best wearing, most reliable tires in the AG market. That said, I've generally found that the casings will disentegrate around the same time as the lugs wear off, or in about 10-12 years. GoodYear didn't have a good wearing or pulling tire, but I always found the DynaTorque to be a very good casing. I've never seen the rot problems with them that Firestone had, and certainly never had the casing failures like I've had with Armstrong and Titan. I'm now moving towards radials, and right now BFG is producing a value radial (read cheap) that looks a lot like a Michelin AgriBib radial. I've got a set of each, and so far I'm impressed with both. Also have a set of Firestone Radial All Traction 23 degree's, and have been well pleased with them. They so far do not seem to have the dry rot problems that I used to see with the Field and Road tires. General was another of the poorest tires I've ever seen as well. Very weak casings, and not a whole lot of lug. They wern't cheap to buy at the time either. So long as my lungs suck air, I'll never have another set of them. Beyond that, I've found that Galaxy/Primex is making a good cheap decent wearing, reliable value bias tire. They're routinely the cheapest to be found, and I can't say a bad word about them, other that that they won't wear like a radial.
I'm not sure that you can find a good light truck tire anymore..... I've got a set of President tires on the truck now, which have been OK so far.... but I've had not so good luck from them before....
Rod
Don-Wi
06-15-2006 13:19:53
 Re: New Tahrs in reply to RodInNS, 06-15-2006 11:52:46
The Good year's my dad took off the 285 were dyna torque's, the side walls were splitting really bad and at the time they were only about 5-7 years old. My Grandpa also has a set of them put on the 1600, and they had the same splitting/cracking sidewall as the others.
It still has it's second set of tires, Power Marks and they are holding up really well. One has a small rip in the sidewall but it's not poking through yet, they will probably last a good while yet. The fronts are getting down there. One is a Firestone and while it's not cracked, it's bald. The other it a General and it's got plenty of tread yet but it's cracked really bad.
Our 1755 came with Armstrong's and they were pretty good, but now the engine is blown. Our 165 has new Titan's (feild & roads ran over a disk about 10-15 years ago) on and so far they are holding up just fine but they're only 3-4 years old.
Our 1855 has Coop's on. While they are splitting some in the center around the lug, it sits outside (to big to go in the shed) and sat on the dealer's lot for about 2 years before we bought it. It's getting new ones in the next year or 2, probably gonna go with either Titans or agri-master.
The 1600 has Agri-masters on, just got them put on last year and I like them. It doesn't do much for pulling or road travel, but it still earn's it's keep. Can't say how the tires will hold up yet.
Donovan from Wisconsin
RodInNS
06-15-2006 14:25:52
 Re: New Tahrs in reply to Don-Wi, 06-15-2006 13:19:53
Don,
I find what you say about the GoodYear's really interesting. You're not the first person I've heard say that on this fourm either. That said, out here on the east coast, I've never really seen any degree of trouble with the GoodYear casings. They generally wear out before they have a chance to crack up. I'm still wondering if the different climates have a different effect. I've had probably 6 or 7 sets of those DynaTorques in different sizes, and never lost any to dry rot or ruptures. Every one came off because it was worn out. It was the big thing they had going for them in my opinion. The Firestone's that I've had have always served well, and wore out, but I do remember some of the Field and Road's from 20 years ago or so that were awful ripe when they were worn out. We were always happy with Firestone tires, and Galaxy tires for that matter. The Armstrong's and Titan's that we've had were factory installed tires on new tractors, and a skid steer. The performance in terms of pull and wear has been good. I can't knock them in that regard. That said, the Armstrong's we had did rupture from a rotten casing after about 10 years. They were close to worn out though. The Titan's that I have now have ruptured a couple times from loading. That said, they were within their load range. That's the first time I've ever seen a tire internally rupture from loading. The casings themselve now are heavily weathered after 8 years. I simply have not been impressed with them. Installing a 100 dollar blowout patch didn't help. Next slip up for them, and they're gone. It was much the same story with the Generals we had. The belts broke in those tires within 2 years. We never got to wear them out. At this point I've pretty much been cured of the need for bias tires anyway. The tractors that have been switched over to radials ride so much smoother that there just isn't any comparison. They do cost more up front, but there's a lot more tire there. The Michelin's especially have 3/4"-1" more lug depth than most bias tires. In the end, so long as the casings hold up, the increased cost will bear out in increased service. The fuel savings, increased pull, and better ride are just bonuses.
The only reason I would not install a radial today was if the tire was going into an application where it would not wear out before it rotted. In other words, on a trailer queen that never works, or doesn't do much.
The only problem I've seen with the 23 degree firestone radials was actually with the tubes. The tire was carrying so much weight, and gaining so much traction that the tractor could turn the wheels IN the tires, and shear the valve stems off. I replaced several tubes from that, and have since started running duals. That seems to have solved the problem. Otherwise, I've been very happy with those tires.
Rod
Don-Wi
06-16-2006 01:18:14
 Re: New Tahrs in reply to RodInNS, 06-15-2006 14:25:52
The bone yard has a set of 23 deg. Firestones that would fit on the 1855, but I have no idea how much they want for them. We have duals for both the 285 (18.4-34's) and the 1855 (18.4-38's). I just ripped open the tread on one on the 285, so one of the old Good Year's went on. Figure they're good enough for that use.
The duals for the 1855 are Feild & roads, but are extremely smooth so they really only provide flotation. When we do get new tires on the 1855, the old Coop's are goin on the dual rims and the F&R's are going on the road with "FREE" signs on them. Costs us $20 otherwise per tire.
The only a tire that got so rotten it just failed was on my 1600 while waiting to be sandblasted (for about 1-2 years). The one remaining Good Year finally let go, but it was severley weather checked and about 20-30 years old. The other Good Year was swapped out for one of the original Factory Firestone's many years before that, and then that one was sliced on the side wall so a used Coop was mounted.
Still a little mad my dad just paid to get rid of the Coop, it still had plenty of tread and I'm sure they mounted it on another tractor, just like they did on the 16. I guess that's just a money making tire for those guys....
Jerry (AL)
06-15-2006 17:28:20
I used to drag race when I was young. We ran a 427 chevy with about 900 horses. We would spin the rim inside the tire we would get so much traction. Ripped a few valve stems too. The solution was to screw the bead to the rim. I was looking at a funny car a neighbor has the other day and noticed that he had small allen head bolts through his rim.
Ron-MO
06-15-2006 11:30:07
Just by coincidence I have been fighting tire problems since I bought a new truck 15,000 miles ago. Originally I had General tires on it, but after two bouts of trying to fix a shake and replacing with the same tire, I told them I wanted new tires (different brand). They installed Goodyears. They were worse. After many failed attempts to find the problem and of course it could not be the tires - "we just put the third set of new ones on" GM recommended a "Road Force Analysis Test". Guess what.....3 tires out of 4 were bad and needed replacement. The dealer put on the 3 new and it is "nearly gone", but I still have a shake in the truck, and my bet is I will until I finally have to replace those Goodyears. The last set of Goodyears I had never wore out because I could not keep them from having flats. Half tread and anything would go through them. I finally bought new tires and that was the end of flat problem. Needless to say I will look at something other than Goodyears from now on.
Randy S.E.-MN
06-15-2006 09:35:19
I've been in automotive for almost 30 years, and even worked at a company owned Goodyear for six months(I walked out on them because they suggested frequently that I find more wrong with a vehicle than there really was), and in all that time Goodyear has consistently been the worst tire I've ever seen. I've owned my own repair facility for almost 19 years now and I will not stock Goodyears...I only install them if the customer demands them. I wont touch a Firestone, never dealt with a Uniroyal. I have had real good luck with BF Goodrich, and Cooper & Dunlop. That is all I will run on any of my personal vehicles.
Jerry (AL)
06-14-2006 18:50:43
I worked for several years for Dunlop here in Alabama several years ago. There is a lot that can go wrong in building a radial tire. Dunlop used to be the only maker that X-rayed every single tire to ensure that the ply alignment was correct. Those things are built in a number of pieces. Dunlop at the time had the lowest adjustment rate in the industry and Goodyear the highest. At that time, Goodyear made 34 different named tires world wide. I have bought a few vehicles that came with Goodyear tires on them and have never had good luck with them.
Dunlop and Michelin were really the same tire back then so I always run Michelin if I can. A bit more pricey but in a tire, you get what you pay for. They have done very well on my trucks and Tahoe.
Michael Soldan
06-14-2006 19:01:59
 Re: New Tahrs in reply to Jerry (AL), 06-14-2006 18:50:43
Hi Jerry,I worked in my friends service garage for three years and I saw a lot of tire failures come into the shop. The only Michlins I took off were ones that had worn out, can't remember any failures with them. We sold a lot of Cooper tires and never had them coming back in either. That convinced me on this set and I think I am going to br happy with them.....Mike in Exeter Ontario
Don-Wi
06-15-2006 00:13:21
 Re: New Tahrs in reply to Michael Soldan, 06-14-2006 19:01:59
My dad used to work at a tire shop for a few years. He said the tires to stay away from are: (in this order) 1. Uniroyal
2. Good Year
3. Firestone
4. Wide Track (Fleet Farm brand)
Uniroyals never hold up to any kind of abuse (or even use for that matter)
Good Year just wasn't any good. The side walls seem to weather check and crack a lot, espescially on the Ag line. We've got a pair that came on our Masey 285 (18.4-34's) with about 50% tread, but he had them replaced about 20 years ago (tractors only about 24!!) because of cracking sidewalls. He had Power Marks installed and 20 years later they still have about 40-50% tread. One of the Good Years just made it on a dual rim for the 285 because I tore the other one open.
Firestone- well we all know about the Ford Exploders. Their Ag tires seem pretty good though, but the ones on my dad's truck (00 Tacoma) handled like crap. Even worse in the winter.
Wide Tracks- Look in the junk yard at all the smashed cars, about 50% have Wide Tracks (or other Fleet Farm Brand) tires on them...
He replaces everything with Coopers, and they prove to be VERY good tires.
I've got a set of Sport Kings (forget who makes them) on my truck, about 3 years old and almost time to replace them, they're a 50,000 tire and I've got about 45,000 on them. I'm happy with them, but I may not be keeping the truck too much longer so I don't know about putting expensive ones on. Too rich for only a few more months of driving.
I plan to put either Coooper's or Sport Kings on my new truck when I finally get the funds to buy one.
We've got about 3 Uniroyals on rims in the shed right now and 2 of them have busted cords and the tread is bulging. Another one on the haybine we bought this year has the same problem, but it's coming off the next time we pull it around to the shop. I'll NEVER drive on a Uniroyal, they just fall apart on us.
Donovan from Wisconsin.
(If ya havn't noticed, I can be a little passionate about some brands)
John17
06-15-2006 12:57:11
 Re: New Tahrs in reply to Don-Wi, 06-15-2006 00:13:21
Those Sport Kings you are riding on are made at the Uniroyal factory in OK. I know that Uniroyal has had a bad name in the past, but they have been sold to Michelin, so the tire is much better today, than it was 10 years ago. I myself will always run Michelin tires on my vehicles, everything else is just not as good. JohnG
Don-Wi
06-15-2006 13:06:39
 Re: New Tahrs in reply to John17, 06-15-2006 12:57:11
The name on the side in real small print is something patriotic sounding, liberty or something along those lines. We"ve had a few Laredo"s on haywagons. They can go either way but 3 out of 5 were junk within a year or 2. We"ve got some old BFG"s that are 20+ years old on a wagon here & there.
