fahr tedder parts
joe/pa
06-14-2006 16:32:29
Does anyone know who might still carry parts for an OLD Fahr KH40 tedder? I'm guessing it's from the 70's but not sure. All of my books are in german. Everywhere local doesn't seem to have any access. I need to know if the yoke and bar (know it's not right name) are still available, or cheaper to make new ones. Parts I'm needing are the yoke and pin that mate when you pull forward the outside baskets and lock them fast. Thanks
Our Farmer
06-15-2006 13:44:49
 Re: fahr tedder parts in reply to joe/pa, 06-14-2006 16:32:29
I have the same model. Built like a brick (out) house, but parts are a problem. Be prepared to be creative.
For replacement wheel hubs I bought 5/8 shaft hubs and ground the axles down a bit. NH tines work good if you use the mounts upside down. The only complaint I have is that green hay winds up around the wheel a lot. Still haven't solved that one.
joe/pa
06-15-2006 15:34:56
 Re: fahr tedder parts in reply to Our Farmer, 06-15-2006 13:44:49
Well got back from the dealer, and got some pins on order, but the yokes are going to be a rebuild. They are still available but almost $100 each.... Kuhn yokes almost fit, but the shear pin size is too big. Don't seem to have too much of a problem getting hay wrapped around the wheels. Only on the left center wheel.
wolfman
06-14-2006 17:38:46
Fahr later became Duetz-Fahr so try your AGCO Allis dealer or their web site.
ryan from WI
06-16-2006 15:05:03
 Re: fahr tedder parts in reply to wolfman, 06-14-2006 17:38:46
Do not go to a Agco dealer. They would not have those parts anymore. If they do they cost you some $$$$ there. Find a Duetz Dealer or call Duetz. It would be alot cheaper and they could get you what ever you what.Or even better call Same-Duetz Fahr. I think it is the same thing now.
