24T Out of time I Think
Horse
06-13-2006 14:40:59
I was baleing and sheered a pin. The stops had came up and stoped the ram. I pulled the needles back and started baleing. The left side would not tie If I moved the twine to the bottom eye of the needle it would miss about every 3rd bale. How do I set the time?
ErnieDD
06-13-2006 17:35:09
 Re: 24T Out of time I Think in reply to Horse, 06-13-2006 14:40:59
Trip the knotter and crank it through by hand so you can watch the needles as they rise up through the knotter frame. You may have bent a needle. Check to see if the needle frame brake is placing a drag on the needle carriage. Lastly check the plunger head slots and insure there is not an accumulation of chaff.
If you did not break a chain and the chain was not so loose that it would skip a tooth, you are not outta time.
A baler operation manual will give you measurements and references/landmarks to measure from to adjust time. If you have a zillion bales on it, it may pay to advance 1 tooth on the little chain to compensate for wear. Before embarking on this I would pay a JD tech to go over the machine.
Check the tucker finger springs, if they break it will give intermittent tieing.
