mf 36 RAKE how should it work
steve m
06-12-2006 18:33:52
I HAVE A MF 36 RAKE CAN SOMEONE TELL ME HOW IT SHOULD BE SET UP AND WHAT THE PROPER SEQUENCE TO USE TO MAKE IT DRIVE THANKS
mn.Chuck
06-12-2006 19:28:14
 Re: mf 36 RAKE how should it work in reply to steve m , 06-12-2006 18:33:52
Each wheel hub has a lever on the outside secured
to a dog inside the hub. The lever for secure
transport sits in a flat strap with a loop on it.
For field work,release lever from the strap. There
should be a cable with threaded rod on end. Rod
should go thru gearbox and have a nut on each end
of the threaded rod. The cable then goes thru a
loop on the gearbox support bracket,then a loop on
the rear left inner frame,then with the spring on
the other end to drilled hole in the left rear main frame. Then when you lower the rake crank to
operating position it automatically goes into gear
You can adjust threaded rod to change the ht.that
it goes into gear. Most people leave the wheel dogs on-OK- but if you are going 60 down the road
I would clip them back. Great rake. Chuck
Jimmy King
06-13-2006 02:46:03
 Re: mf 36 RAKE how should it work in reply to mn.Chuck, 06-12-2006 19:28:14
If you are going down the road at 60 MPH it is best to take the PTO off from wheel to gearbox.
