Lely disc mower
KEH
06-10-2006 17:00:05
Question:
A relative has a 9 foot Lely 3ph disc mower. Unlike the 7 ft 10 in models, the 9ft has a strut going from the curtain support to the cutter bar to reinforce the mower. In tall, thick hay some of the hay will catch on the strut and he has to stop and clean it off by hand. Is there an attachment to prevent this? Disc mower was made up from two mowers. Do other makes with this support strut have this problem? Thanks in advance.
KEH
RodInNS
06-11-2006 18:03:41
 Re: Lely disc mower in reply to KEH, 06-10-2006 17:00:05
As far as I know, that's common to most any mowers with that end support. It was a particular problem in heavy tangled crops. Both of the PZ and Kuhn mowers I have, have had this problem. The newer style Kuhn's have eliminated the support, and I think the wrapping problem.
Rod
Cliff Neubauer
06-11-2006 15:54:45
Our New Idea 5409 mower has a support like that and it will drag once in a great while but the hay will usually fall off when you raise the mower. Our Case IH MDX-91 mower doesn't have an end support and it will mow through anything without plugging.
Hay DR
06-11-2006 12:13:48
Do you have a Optimo or Splendimo series mower? There are 3 different ways to go. You can used a Vermeer, Haymaxx or Lely end support.
KEHh
06-11-2006 16:00:11
 Re: Lely disc mower in reply to Hay DR, 06-11-2006 12:13:48
Thanks for replys. Hay DR, the mower is an Optimo 280.
KEH
504 Baler Guy
06-11-2006 07:15:45
Make sure that the swather board is working properly and not bent up. That is mainly to clear a way for the gear box, but might help the other problem also. Also try not to run the end in prevously cut hay.
