NH 850 baler problem. Will not stay closed
old
06-10-2006 16:21:45
Well here is what I have tried so far to fix my problem. Adjusted the lock valve, switch input and out put from tractor. It will bale one maybe 2 good bales then the hatch will creep open and then of course I either can't tie the bale or if I catch it I get a bale about 3 foot around. I have it stiing right now with the hatch open to see if maybe the cylinders are leaking. I'm also thinking about changeing hyd fluid in the tractor since it looks a little milky. Any body have any ideas of what is wrong with this. I'd chack with a dealer Monday but sure would like some ideas sooner then that and the manual doesn't have a trouble shooting area in it. HELP please.
Thanks
Allan In NE
06-10-2006 16:55:19
 Re: NH 850 baler problem. Will not stay closed in reply to old, 06-10-2006 16:21:45
Does your baler have the tailgate locks? If so, are they adjusted correctly?
Allan
old
06-10-2006 17:43:46
 Re: NH 850 baler problem. Will not stay closed in reply to Allan In NE, 06-10-2006 16:55:19
Only locks it has as far as I know are hyd locks in a lock valve, the book says nothing about any other ones
TimS
06-10-2006 16:54:37
I would have to say either the valve is leaking or the cylinder(s) are.
Isolating the cylinder like mentioned above is a good idea.
KEH
06-10-2006 16:53:05
I would change the hydraulic oil for the sake of the tractor, but I don't think that will solve the baler problem. I'm curious to hear what the dealer says. Good luck.
KEH
olepigfarmer
06-10-2006 16:51:02
old, Had the same problem last year with my New Holland 849. Found that one of the cylinders was bypassing fluid around the pistons seals. Allowing pressure to build on that side , effectively raising the door. I narrowed it down to which cylinder by closing the door, removing the hyd. line from the port on the raise side of one cylinder at a time and then watch for hyd. fluid coming out of that port while closing the door. Got a cylinder rebuild kit at the local N.H. dealer. Fixed the problem. May be that is your problem too.
