Grinder/Mixer Education Needed!
Matt in PA
06-06-2006 18:56:44
Hello,
I am in need of an education with regards to feed grinders. I have started finishing about 10 head of beef cattle a year and would like to grind my own feed. My problem is I don't know what to look for when it comes to selecting a good use grinder/mixer. My largest tractor is a JD 4020, so I need something to fit that hp range. Any suggestions please!
Thanks, Matt
RickL
06-07-2006 10:50:23
 Re: Grinder/Mixer Education Needed! in reply to Matt in PA, 06-06-2006 18:56:44
Matt in Pa; we always ran gehl units model 65 to 95 to 120 model units. 95 unit would be gerat for you. changing screens is simple on those units. for the fats we never ran it with the screen that just left it kinda cracked. have three of them in the shed all for sale as parts or still could be used . we don't use them now. have another larger all hyd unit now.
SHeiserman
06-07-2006 19:24:17
 Re: Grinder/Mixer Education Needed! in reply to RickL, 06-07-2006 10:50:23
Where are you located?
RickL
06-08-2006 01:10:26
 Re: Grinder/Mixer Education Needed! in reply to SHeiserman, 06-07-2006 19:24:17
southeast Iowa
SHeiserman
06-08-2006 16:44:57
 Re: Grinder/Mixer Education Needed! in reply to RickL, 06-08-2006 01:10:26
Sent you an e-mail, thanks.
Nebraska Cowman
06-07-2006 04:21:36
Any of those older grinder mixers would do fine. Use a big screen and keep the rpms down so you just crack the corn. I'd look for roller mills too. When you get to feeding a critter 25 pounds of corn you don't want it ground fine. Will you grind hay too? I'm no feeder but I think you want around 2 pounds per day. third party image
