Rating Front Loaders
D Ward
01-28-2000 16:54:55
I am in the market for a front loader for a MM 1355 (130 hp). I tried a used one that was obviously for a lighter use, busted it. How are these things rated besides quick detatch, width of bucket and height of lift? Is there a rating like the category I,II,III 3-pt hitch?
I'll move some dirt, mostly move logs to a sawmill and out of the timber. Some haybales, gravel, etc.
Any comments greatly appreciated.
bbott
01-30-2000 18:22:53
 Re: Rating Front Loaders in reply to D Ward, 01-28-2000 16:54:55
Keep in mind that transporting material over long distances in a loader bucket is really hard on a machine.... especially those that weren't designed for loader service to begin with.
Bumping over rough ground coming out of the woods with a load of logs may cause the MF some troubles..
bbott
RickB.
01-29-2000 06:29:08
Most loader specifications are comparable as they are developed from ASAE standards, meaning they are measuring lift capacity, breakout force, and dimensional data using a defined set of criteria. Unfortunately, if you are considering a used unit, you must find info from original sales literature, or compiled info from a source such as Implement & Tractor, or NAEDA. Good Luck.
