vermeer 504 baler question
Ed Larson
06-04-2006 17:16:11
I am looking at a 504 super F to buy.I dont know much about vermeer balers.I currently have a 410 Deere baler.What are the good things and bad about the machine?How tight of a bale does it make?And finally will a D17 Allis handle the baler?
gc ks
06-07-2006 05:17:15
 Re: vermeer 504 baler question in reply to Ed Larson, 06-04-2006 17:16:11
I have a 504G and I use to pull it behind a Farmall 350. Now i pull it behihd a Farmall 560 and like it much better.
JM in Merit
06-05-2006 17:18:44
I had a 605 F model and had good luck with. Ran it about 15 years, no major problems, just a few bearing going out. It made in MHO a tight bale. I have moved up to a 605 K this year. It is different from th F model, think I am going to like it allot once I figure out all the settings on it
Hay DR
06-04-2006 21:50:58
 Vermeer 504 baler question in reply to Ed Larson, 06-04-2006 17:16:11
There were not that many of the 504 Super F balers made. Most were 504F balers.The Super F were the last models of the F series. Likely that Super F has an electric twine tie. A 504 Super F is close to being a 504H.
The JD 410 baler is a closed throat baler and the difference would be night and day between these 2 balers. The Vermeer 504 Super F will make bale so tight that you will have trouble spearing them. If you short on HP in your tractor you can also change the main drive sprocket and reduce the HP requirements 10 HP. This can be done for less than $50. Value for a 504 Super F would be $2,000-4,000 if in average to above average condition.
Doug in IL
06-05-2006 19:17:47
 Re: Vermeer 504 baler question in reply to Hay DR, 06-04-2006 21:50:58
Where does the 504 G series fit in. What is different from the F, Super F or the H models? I"m thinking of buying a G. Thanks!
Hay DR
06-06-2006 06:11:53
 Re: Vermeer 504 baler question in reply to Doug in IL, 06-05-2006 19:17:47
G & Super G balers are spring tension on the belts. F & H balers are hydraulic tension on the belts.
Doug in IL
06-06-2006 07:14:25
 Re: Vermeer 504 baler question in reply to Hay DR, 06-06-2006 06:11:53
Does the spring tension system on the G baler mean that it would not be a good choice to buy? Will they bale a good, tight bale? Is the spring tension a problem?
Hay DR
06-06-2006 17:04:26
 Re: Vermeer 504 baler question in reply to Doug in IL, 06-06-2006 07:14:25
G & Super G balers will still make a good tight bale with spring tension. By now the springs have likely been replaced once.
KEH
06-04-2006 18:14:22
I had one of those with Massey Fergueson paint on it. First, it won't make your D17 breathe hard. They are very east to pull. They are well made. If the pickup has all the teeth and the proper adjustments are made it will start bales reliably in any kind of hay. Unless it has electric twine wrapping, it requires 2 hyd. outlets, one to dump the bale, the other to work the twine arm. The twine arm mechanism is a little fragile, but works fine with reasonable care. Mine did not want to cut the twine reliably until I made a longer twine knife out of an old sickle blade. This involved grinding it to shape and drilling new holes in the blade. Belts need to be trimmed to the uniform factory length, but that is true of any belt baler. It does not make bales as tight as newer Vermeer or JD balers. IMO good tight bales start with the Vermeer 504I or better 504 Super I. Good JD balers start with the 430 IMO. I suspect the 504F makes better bales than the JD410, but I don't know. I do know from personal experience that it makes better bales than a NH 847. Hope this helps.
KEH
