NH68 and Farmall 706 haying photos.
Kelly C
06-03-2006 21:13:38
Got a few photos of my 706 baling hay. Talk about a gas hog. 706 is not going to unseat my 400 from baling duty any time soon.. 706 will come out when its time to use the chain baler. Too bad to because this is sure a comfortable rig to use. But she uses more than twice the gas to do the same work as my 400. I put 27 gallons of gas in her. Didn't use it all but dang near. This is only 6 acres. That did include about 36 mi road driving. So maybe not as bad as I think.
third party image
third party image
third party image
My NH68 worked the best it has ever ran. Not one miss tie or any broke shear bolts. That's a first for me.
Got to do a field non stop. Not quite as shinny as she used to be when I 1st got her rebuilt.
third party image
third party image
400 was there to cover the raking duties.
PW ON
06-06-2006 05:57:57
 Re: NH68 and Farmall 706 haying photos. in reply to Kelly C, 06-03-2006 21:13:38
Kelly ; What ever happened to the NH 268 w thrower? I never read any more about it. Did you fix it or is it still in waiting? I bought the same thing last fall and am just waiting for things to dry up here and will start haying. Can't wait to try her out. Paul
Kelly C
06-06-2006 19:23:44
 Re: NH68 and Farmall 706 haying photos. in reply to PW ON, 06-06-2006 05:57:57
third party image
Still have it.Trying to decide if I want to put forth the effort to get her into shape. I do plan on moving to a thrower system as my wifes alergies are worse now and she cant run the baler.
So for now its just me. Cut it, rake it. Pick them up, Stack em,
Should have good Poppey arms by the time 1st cuttings done :-)
4 bale baskets would sure be nice right now. $6,000 to get them would not.
Going to start converting my flat racks to thrower racks soon as I sell some hay. Then look at that 268.
RickL
06-07-2006 10:12:27
 Re: NH68 and Farmall 706 haying photos. in reply to Kelly C, 06-06-2006 19:23:44
Kelly C; If you still looking for round balers have a pair of them at 1500.00 ea. i know you said bale basket wagons were out,but boy would I rethink the idea. I grew up behind kickers and when I went to the basket wagons man was that way way way simpler no more kicker headches,no more misses in the hills and way eaiser to unload in to elevator or customers trailers.you can get them anywhere from 700.to 1500.00 used. i still running accumulator setup but i know if I chose to change again it would be the basket wagons again. I got along so well with them. good luck. Accu,mulator grapple that is the cats meow thou. at least for me
Kelly C
06-07-2006 19:51:52
 Re: NH68 and Farmall 706 haying photos. in reply to RickL, 06-07-2006 10:12:27
Baskets would be great. Maybe I could start with one and dump the bales close together and save the driving and walking to pick them up. Hmmmmm
RickL
06-08-2006 00:57:00
 Re: NH68 and Farmall 706 haying photos. in reply to Kelly C, 06-07-2006 19:51:52
that would be a start anyway. what I done when I had them at the last was use them with a small bale grapple. we just moved the dump pile into bundle of ten then lift ythem on to trailers ot to the sheds with loader real didn't work that bad thats when i knew that I wanted to really go the accumulator grapple route if could find one. do you have old loader on on of your old tractors.if you do then would help even more. You keep doing it like you are and it gets old really fast. I been there done that. I really doubt that after setting up the way I am if i physically touch more than 20 bales all season long by hand is rarety. those grapples are slick.
PW ON
06-07-2006 05:31:22
I just built my first thrower rack wagon this winter. Now am waiting for the right weather to try everything out. This will be first year with thrower set up. Paul
Hoosier Pete
06-05-2006 14:55:27
Great pic's Kelly. I know what ya mean on fuel. My Oliver 1800 gas uses 5-6 gallon per hr. whether your mow'in or disc'in. But, when I think of what I paid for it I can buy a whoooole lot of gasoline.
Pete
Bullfiddler
06-05-2006 07:20:23
That's why you need a David Brown 1200 in the shed. I just mowed, raked (X2), baled, and hauled in 6 acres on about 7-8 gal of diesel.
Allan In NE
06-04-2006 05:56:18
Mornin' Kelly,
I agree. Those darned 6-pop gassers will make your ears bleed by their high fuel comsumption.
I'm puttin' mine back under a loader and will find another diesel somewhere.
Thanks for taking the time to post the pictures. Always enjoy your farmin'. :>)
Allan
RickL
06-05-2006 05:45:21
 Re: NH68 and Farmall 706 haying photos. in reply to Allan In NE, 06-04-2006 05:56:18
Have a diesel hydro unit coming in on trade looks like if that help
BC in TN
06-04-2006 00:59:51
Kelly - I sure enjoyed the pics.
Can you tell me how you post multiple pics. I understand the process for a single photo. I've tried to separate the htmls by comma and semicolon to no avail - I can only get one on there.
hillbillyOH
06-04-2006 03:58:40
 multiple pics in reply to BC in TN, 06-04-2006 00:59:51
Follow this format, replacing the square brackets "[]" with HTML brackets "<>".
[img src="pic location"] [p] [img src="pic location"] [p]
... And so on and so forth. The [p] will properly situate the pics for vewing.
JarrodS
06-03-2006 22:53:00
Nice looking outfit. My nieghbor has a 706 gas on his dairy farm---it uses 7 gallons an hour work or play...so this seems to be an issue for these tractors.
Kelly C
06-04-2006 04:36:40
 Re: NH68 and Farmall 706 haying photos. in reply to JarrodS, 06-03-2006 22:53:00
third party image
Well I knew she used gas when I purchased her. I had been told. 7 gal a hr seems to be true.
If I dint have another to use I would just chalk it up as a cost to save the extra $3000 to get a 706D.
Man my back is howling at me this morning. 6 acres all by your self seems like more. I am not 20 years old any more.
Illinois Boy
06-05-2006 07:58:29
 Re: NH68 and Farmall 706 haying photos. in reply to Kelly C, 06-04-2006 04:36:40
Nice pictures Kelly.
It seems to me all the 6 cylinder Farmalls eat the gas. Diesels don"t seem to be quite as bad, but may just be me. Guy across the road has a 666 and it"s pretty much a gas hog to.
If you"re pulling equipment that far to put up hay - my hat"s off to ya!!! (Do you get honked at a lot by the yuppies in their SUVs or are people pretty patient there?)
Kelly C
06-05-2006 21:45:43
 Re: NH68 and Farmall 706 haying photos. in reply to Illinois Boy, 06-05-2006 07:58:29
Oh man I am a expert at road tripping hay racks.
This field is easy. Only 6 mi from the house. Made 3 trips though.
The land I own is 30 mi away.
I keep a mower, baler and my 400 up there all summer or trailer it back between cuttings.
I only have the one rake so it trips.
I pull 2 racks full at a time the 30 mi with my F150. I made a extension for the rear of the front rack so the trailing one has enough room.
I can go maybe 30 mph on the good streaches.
20 mph on the bad.
Empty its 45 or 50 mph if no cars around. 20 mph if any cars loaded or empty.
I have a route that runs on all township and County roads so I mabe only get passed by 3 cars the whole trip.
I would not ever concider pulling any of my stuff on a state rd or any thing like that.
Ia Roy
06-03-2006 22:09:27
706 and 68 is the same combo we used in the late 60's. My little brother used to run it from the time he was about 10. Sounds like way too much gas for what little you baled. I know we used to bale from 1 till at least 7 or 8 and not be empty. That baler didn't come close to working the tractor. Maybe we just had better gas then.
BigMarv1085
06-04-2006 05:05:53
 Re: NH68 and Farmall 706 haying photos. in reply to Ia Roy, 06-03-2006 22:09:27
Hey Kelly, my 966 uses about 7 gallons of diesel a hour also.
Rexalot
06-05-2006 06:46:51
 Re: NH68 and Farmall 706 haying photos. in reply to BigMarv1085, 06-04-2006 05:05:53
Getting ready to do my hay with my Oliver 1800 and NH 68 combo, this will be my first year using the 68 behind the Oliver in years past I used my S67. (I have since retired that baler for parts as it needs some work.)
I used the 68 last year behind my 871 Ford. I had problems making banna bales in grass hay, so I tried fat windrows and that helped some. This year I added an extra set of tine bar forks since I saw where Kelley had done it in his baler. My question for Kelley is, did it work? I have set the tine bar forks equally spaced at about 10 inches. I set my tension springs equally using a measuring stick and the bale length is about 3.5 to 4 ft. I also have the books.
Those bales of your look really good.
Kelly C
06-06-2006 19:41:36
 Re: NH68 and Farmall 706 haying photos. in reply to Rexalot, 06-05-2006 06:46:51
Never have got a bannana out of my 68. The only real problem I have had was breaking shear bolts by the dozen. Used to break one about every 25 or 30 bales.
I tried every thing to fix it. I had it timed exactly as the book said so I thought I had another problem. Messed with the safety catch alot. Adjusted the bale tension thinking I was baling too tight.
I was almost ready to turn her into parts and just use my 14T.
Then I remembered that when I got the baler I had checked the timing and found it advanced one chain lenth from the book.
I put it back where it had been. I havent broke a shear bolt since then.
Stupid me, The chain had streached with age.
The only Issue I have with it now is. I need another pick up assembly for it. The one I put on from my parts machine is wore out. The pipe holes are all wobbled out and the cam is so thin it dents like tin foil. Have to take a big hammer and a pipe to whack it back into shape if she digs dirt any time.
So I am on the watch for another parts machine with a good pick up assembly.
bvomark
06-05-2006 08:25:59
If your bales are running 4 ft long that seems too long for me. Makes for difficult stacking and handling. Usually hard to get nice tight bales as well. I always thought the ideal bale length was 36". This is twice the width of the bale and allows nice stacking, tighter bales.
Rexalot
06-06-2006 05:41:48
 Re: NH68 and Farmall 706 haying photos. in reply to bvomark, 06-05-2006 08:25:59
I measured my bales, like a fish story I made them bigger (longer) then what they are. They average is just over 3 foot in length with a few close to 3.5
I did 186 bales of orchard,alfalfa, and clover mix. Dry stuff lots of chaff. I had two bales that didn't get tyed when it switched twine balls for each knotter (I guess my knots between twine rolls still not small enough to pass through the needles)and the help pulled the string off three bales. After about 40 bales I got it figured out on how to make them square by alternating the tension springs, tighter for the long side. Good bye bananna bales! The addition of an extra tine bar forks seemed to have helped to. Chain on the left side between the plunger drive and the knotters broke on the first round - just old, but luckily I had a spare on the S67. No problems after that.
