JD 350 and 450 Sickle Mower Question
Another Bill
06-03-2006 17:51:14
A 1996 JD "Hay Preparation" booklet I have on MoCo's, Rakes, etc. also includes info about the 350 and 450 sickle mowers. It says that as the cutterbar breaks away, the sickle stops to help prevent damage. No more description is given. Can someone explain the details of how this works?
Thank you in advance for the information.
John51
06-03-2006 18:40:34
 Re: JD 350 and 450 Sickle Mower Question in reply to Another Bill, 06-03-2006 17:51:14
It's real simple. There is a brace that runs diagonally back to the inside end of the sickle bar. It is held in position by a heavy spring. If you hit an obstructuion, it will release from the bar and allow it to swing back. As the sickle bar pivots back the tension is released on the drive belt so the blade stops moving. Questions?
Another Bill
06-03-2006 21:13:33
 Re: JD 350 and 450 Sickle Mower Question in reply to John51, 06-03-2006 18:40:34
John51:
No questions at all after the clear explanation that you gave. Thank you!
