IH 35 Hay Rake -- I need Help
Iowa Jim
06-03-2006 06:11:40
I posted this on another bulletin board, thought you all might be able to help.
While raking hay last Friday my IH 35 rake quit spinning. I opened up the gear box then removed the spider gear and discovered that the back side was "stripped". So up to this point I am frustrated, but optimistic.
I just called my local IH dealer and was shocked! CaseIH no longer sells the individual gears for this rake, you have to purchase a "gear set" for $462.20. Well, I could invest in both gears and have a good rake, I already replaced the bearings in the gear box two years ago, but I wanted to see if anyone on this board knew of a source for the individual gear, part number 540773R1.
Jim Smith
Jason Simmerman
06-05-2006 11:32:03
 Re: IH 35 Hay Rake -- I need Help in reply to Iowa Jim, 06-03-2006 06:11:40
I would like others said look for a parts rake or better yet look for a working rake and use yours as a parts rake. There are so many possibilities as to why the gears stripped out. Case could be warped or a shaft is warped. Everything could be fine but then again maybe something is gone. If you can't find a parts rake for what you are gonna spend in parts then maybe it is worth it but I bet you can find a rake for a couple hundred.
j cook (iowa)
06-05-2006 10:19:00
Sometimes when you are using really old equipment and discover that the price for repair parts exceeds the replacement alue of the rake, the best thing to do is to try and sell your broken machine to a salvage yard for more than fair scrap value, and just get another machine---one that already works. If you buy another rake of the same model, then you will have your own parts source. I gave up on a JD 640 rake a few years ago when it started looking like it would need expensive parts.
RickL
06-03-2006 06:21:59
You will have to find a parts rake,will be you only other choice from what we learned also.
