Oliver 356 sickle bar lift cable replacement
ironhoarder
06-02-2006 07:28:38
I am trying to get my Oliver 356 7' sickle bar mower working so I can cut hay with it (I got it last fall and have never used it).
One of its problems is the lift cable that raises the cutter bar via the 3 point hitch. The cable is broken.
The 7/16" or so wire rope somehow connects to a 1/2" threaded rod inside of a big spring. The threaded rod attaches to a yoke. The cable is supposed to go through the big spring, wrap around a pulley and hook to the 3 point top link. The cable broke just past the spring.
Problem is- I have not been able to get it apart. Where the threaded rod threads into the yoke, I cannot break this free.
OF course, even if I do get it apart, I don't know if I'll be able to come up with a suitable replacement. How the heck do they transition from wire rope to threaded rod inside the spring anyway?
Thanks
mike in ont.
06-02-2006 17:20:34
 Re: Oliver 356 sickle bar lift cable replacement in reply to ironhoarder, 06-02-2006 07:28:38
I can"t believe someone else has a 356. I found the lift system on these to be one of the most frustrating to work on and set-up. My cable is so frayed I am afraid to use it and I have not figured out how the cable is connected to the threaded rod, I think there is some kind of crimp. All tractor parts dealers I ask about the 356 have never heard of it. Mine has MF,NH and IHC part on it that I have modified to make work. Make sure the pulley system is working good and that the cable dosen"t come off and wrap around the bolt, I think thats what wrecked my cable. Sorry I can"t help, but I"m glad I"m not the only one that has one of these. Good Luck Mike S
P.S Buy a haybine.
nballen
06-02-2006 11:55:28
Couppla ways...without a picture, its hard to tell exactly how the pieces connect.
One way...
An eye-nut would thread onto the threaded rod, and a pair of wire-rope clips to form a loop in the wire rope. Or you could have your local rigging supplier permanently attach the wire rope to the eye-nut with a compression sleeve. Your favorite search engine will likely turn up images of these items. Parts would be readily available from most hardware / farm supply store.
Nathaniel
