Sharpening Cutditioner Flails
Formerly PaMike
06-01-2006 09:27:01
Does sharpening the flails on a cutditioner help the cut quality much? Ours doesnt give a clean cut at all, but I am guessing that is just the nature of the beast. Anybody ever sharpen the flails and notice a differenc?
Thanks
burnetma
06-03-2006 17:17:26
 Re: Sharpening Cutditioner Flails in reply to Formerly PaMike, 06-01-2006 09:27:01
I have a NI 272. I sharpen mine after every 30 acres. I have not removed the flails yet to sharpen. Frankly, I am a bit concerned about doing so because some of the flails are hung up and I am concerned that I might not get it all apart or all back together. Either way, my experience is that no matter how sharp you get the blades, the grasses will look a little ragged.
FYI, I absolutely love my Cut/ditioner. Downed hay no problem. Clogging - not a problem. Wood chuck holes - no big wreck. Unit is tough as nails and simple to maintain. I will not set any speed records mowing hay, but I sure might set some drying hay.
joe/pa
06-03-2006 15:15:54
I usually sharpen my cutditioner flails before first cut and before second cut (depending on how many rocks, etc I hit).
troy1985
06-02-2006 19:30:12
i have a a new idea cutditioner 4 sale if anyone needs one... its in good shape....
swbailey
06-15-2007 19:24:20
 Re: Sharpening Cutditioner Flails in reply to troy1985, 06-02-2006 19:30:12
Would be interested in the unit or parts.
Where are you located?
Scott NH
TomTX
06-03-2006 06:06:56
Where? Model? How much?
Tom
Jim-in-NY
06-02-2006 13:03:30
www.shoupparts.com
Jim-in-NY
06-02-2006 07:02:10
I thought i was one of the only ones to still use a cutditioner. Yeah sharpening makes a big difference. i take them off and sharpen them. I shoudl do it more often but i only do it once a year unless i break some.
hayray
06-01-2006 11:40:34
You are talking about the flail knives right? I sharpen mine all the time. Two ways I do it is out in the field with a cordless angle grinder. I hold the tip of the knife with a vice grip and then sharpen the beveld edge and grind out the knicks. I also take them off and sharpen on my belt sander when I have more time. If I am mowing for a full day then I will sharpen in the field and I also always carry extra knives to replace ones that are too bent up. Sharpening makes a huge difference after about 40 acres.
Formerly PaMike
06-02-2006 06:05:32
 Re: Sharpening Cutditioner Flails in reply to hayray, 06-01-2006 11:40:34
I am refering to the New Idea Cutditioners that use a bunch of flails on a drum. They are from the 1970's or so.
evilboweviel
06-02-2006 12:45:26
 Re: Sharpening Cutditioner Flails in reply to Formerly PaMike, 06-02-2006 06:05:32
where can I buy replacemnet knifes for mine need two or three
Ron
