Gearbox ratio information
fixitforfree
05-28-2006 21:15:21
Does anyone have or know where I might find something on the web or in print showing the gearbox ratios on shredders, etc? I have seen a catalog type publication somewhere that showed many common types of gearboxes readily available on rotary mowers along with there ratios, and a picture of each and I would like to get my hands on something like that again. Anyone know where I might find this info?
JMS/MN
05-29-2006 08:32:46
 Re: Gearbox ratio information in reply to fixitforfree, 05-28-2006 21:15:21
Look for Hub City- Safeguard Power Transmission Company in Aberdeen, SD. 605-225--360. They build a wide variety of gearboxes, including those on older Case, Owatonna, JD skidloaders, etc. Likely make some for shredders, etc.
fixitforfree
05-29-2006 19:49:28
 Re: Gearbox ratio information in reply to JMS/MN, 05-29-2006 08:32:46
Thanks for the info. I have a Rhino CY60 that is a great mower but the gearbox turns the blades so slow. It is made to cut rough stuff. I am looking for a drag type mower and I want to put a high speed gearbox on it to make it cut grass pretty. I was given a gearbox/driveshaft/slip clutch assembly that is in good shape off an old Mohawk shredder. The gearbox is a real round shape and says "Warner Auburn Ind." on the back and it has the number 611 stamped on the side of it. It appears to be a 1.5:1 ratio. That is no doubt fast than my Rhino but I want to find some printed info on what gearboxes were offered with even a higher ratio than that so I know what to keep my eyes open for. Are you familar with this type Warner gearbox?
JMS/MN
05-30-2006 07:08:47
 Re: Gearbox ratio information in reply to fixitforfree, 05-29-2006 19:49:28
Not familiar with Warner. Dodge is also another box mfgr. Hub City catalog is over 225 pages of models they make. If you're going to modify a cutter- consider adding extra blades at 90 degrees rather than doubling the speed.
fixitforfree
05-30-2006 15:19:02
 Re: Gearbox ratio information in reply to JMS/MN, 05-30-2006 07:08:47
By modifying I will simply try to locate a factory built gearbox that has a higher speed than most. My neighbor has a cheap made 6' 3-point mower that has a very high speed gearbox. My idea is to take a gearbox like his and mount it to a well built drag type mower with a hydraulic cylinder to control the height. With this setup I will be able to keep high ground speed and still cut the grass good due to a high blade speed and also keep the mower at the height I want on the fly to keep a good manicured look.
