twine
wide axle
05-28-2006 19:03:44
Where can I buy 7800 feet baling twine in KY, OH, or IN? I think it is 7800 ft. or there abouts.
JJ. in B.C.
05-29-2006 09:14:14
 Re: twine in reply to wide axle, 05-28-2006 19:03:44
Last year went to buy the 7200 i have been using for years in my old MF, was told it was no longer available and had been replaced with 9800. Same thickness, same price !! go figure !!
JJ.
Hurst
05-29-2006 07:34:28
You may give Giles Farm Equipment a call. They are in Georgetown, Ky. If anyone will have it in central ky, I would think they would. They have a good amount of twine, sisal and plastic. Good luck
Hurst
RickL
05-28-2006 23:08:31
I use 7200 single rolls poly if that helps,could send you some also if that would help. I am talking poly thou not twine string stuff.
Randy as in Randy-IA
05-28-2006 21:31:36
I've never seen 7800 but 7200 is all over here in Iowa . ...Randy
kyhayman
05-28-2006 20:00:49
Im not saying you cant get it anywhere, but at least in central KY 9,000 and 10,000 is all I've ever found for squares, 16000 for rounds.
