little genius plow
Walter39
05-28-2006 16:21:48
I need help!What color is the rear rim ? silver or cream, What color is the hitch black,blue or black and blue together.And what color are the lug bolts.How can I find out how old this plow is? It has rubber tires w/solid rims Thanks
Thack
05-28-2006 21:00:44
 Re: little genius plow in reply to Walter39, 05-28-2006 16:21:48
This should help.
Larry806
05-28-2006 19:16:23
third party image
Here's one I did a couple years ago . It don't look it but the wheels are cream . The tail wheel is silver. I found those original colors when sandblasting.
Nebraska Cowman
05-28-2006 17:52:10
I was told by one guy that swears up and down that he has it correct they were painted silver but I have seen enough of them with traces of original cream paint to believe otherwise. Maybe IH used both?
third party image
Sid
05-28-2006 20:28:46
 Re: little genius plow in reply to Nebraska Cowman, 05-28-2006 17:52:10
What happened did you burn your knife? I'll bet you have had your tongue stuck to a pump handle too.
MN Bob
05-28-2006 18:42:48
My eyes are older than that car by far. Is that a 55 behind you?? Bob
Chris(WA)
05-28-2006 17:33:02
Rear trailing wheel is cream, the hitch is black. Never seen a genius on rubber so can't help with the lug bolts. The steel wheels were cream and the center cap was blue.
kirk in Ks,.
07-13-2006 16:46:17
 Re: little genius plow in reply to Chris(WA), 05-28-2006 17:33:02
To chris in WA,
I have a little genius 3-16 on steel wheel,s
I see on this one the wheel,s are a straw color, or even faded yellow, but i dont think so,
definetly not cream,
Yes the frames are red, and undreside,s blue,
My blades are chrome,as Ive seen a few like this,
Left wheel is larger of course, but this one is
wider too across the top,
Instead of the narrower type ive seen,
Really a piece of Iron to say ther least!
I have a JD steel wheeled two row planter too,
I think late 30,s,
Im wanting to redo it also,
Ive been bit by the Antique Iron Bug,
and there,s no cure for it except to see thing,s redone as origianl,
