Minn. Moline Grain drill Model PF3-7 problems
Buz Brandes
05-27-2006 23:21:23
Having trouble getting the left side (driver side) to feed seed. Seems like some of the gears don't turn to make the "auger" kick the seed out of the bin. I've taken the wheel off and inspected the gearbox (fine) but I can't figure this thing out!!! It's killin' me cuz I'd like to plant some beans here next week.
Thanks
Buz
JMS/MN
05-29-2006 08:11:15
 Re: Minn. Moline Grain drill Model PF3-7 problems in reply to Buz Brandes, 05-27-2006 23:21:23
Besdies the possibility of a key being sheared- there is a spring on the drive assembly that needs enough tension to keep the gears meshing. Check that it pulls the gears tightly together when in operating position.
Glen in TX
05-28-2006 10:27:37
Check closely to see if a shaft or key is twisted off in a gear.
Buz
05-29-2006 01:22:54
 Re: Minn. Moline Grain drill Model PF3-7 problems in reply to Glen in TX, 05-28-2006 10:27:37
Glenn, could you expand on that a little more.. What do you mean by a key? Something that keeps the gear on a shaft? Thanks
