transit position for JD 350 mower
DreamingGreen I
05-27-2006 18:08:07
I have a JD 350 sickle bar mower, 3-pt hitch with 9' cutter bar. It's too tall to go through our shed door with the bar in the transit position (nearly straight up).
Will it do any harm if I remove the bolt and plate that prevents it from folding beyond vertical? (If I were to remove it, the bar's weight would come to rest on the lift arm for the inner shoe against the crankcase casting.)
Thanks,
Larry
Bob
05-27-2006 19:55:37
 Re: transit position for JD 350 mower in reply to DreamingGreen IN, 05-27-2006 18:08:07
I have a 450, same setup, except trailer-type, and do that all the time to put it in the shed where I store it.
If you hit a BIG bump driving it around like that, it could probably flop over, hurting itself, or someone, but just to put it away should be no problem.
DreamingGreen IN
05-28-2006 17:46:32
 Re: transit position for JD 350 mower in reply to Bob, 05-27-2006 19:55:37
Thanks, Bob.
