mower blade bushing
Bruce in Ks
05-25-2006 21:29:15
Have an old bmb shredder I guess it is called. The small thick bushings that fit inside the big hole on the blades that the bolts goes through were worn. All I could find are bushing of the same diameter, but about 1/8th inch thinner than the blade, so the bushing may float up and down a bit. Anyone see any problem with this? Inside and outside diameters of bushing are tight with bolt and blade.
Thanks!
Jerry Coulter
05-26-2006 15:04:13
 Re: mower blade bushing in reply to Bruce in Ks, 05-25-2006 21:29:15
Sounds like a good fit to me. The bolt or nut has to tighten against the blade. If it were to tighten against the bushing, the blade would slip under load.
