new holland 65
farmerblew
05-25-2006 13:00:14
Can anyone tell me what year the 65 was manufacture? Also any advise to get uniform tight bales out of it .It works ok but for a few misses and dropped twine and the knot stays on the bill hook.Any advise is appricated . thanks
mn.Chuck
05-25-2006 13:54:58
 Re: new holland 65 in reply to farmerblew, 05-25-2006 13:00:14
years of production 1960-1965. Keep the chamber
full-if windrows are light rake two together or
increase speed if field permits. Add wedges to
chamber pn 32124 if my memory is ok??. Sometimes
these have been taken out-or worn out. Or add
more than original. NH sells full length or small
wedges. Get an owners manual. The baler will tie
great if set right. Some good ideas from last
responder. Chuck
shawnspeed3
05-25-2006 13:14:40
I have a New holland 68 and had some of the problems you mentioned ....Knots on the billhooks, make sure the billhooks stay polished with no pitts, also these older bailers like sisal twine not plastic. As far as the bale consistincy goes, I adjusted the bale plunger,but havent sharpened the knife yet, this helped some, but noticed 2nd cutting always had better more consistant bales, 1st always had shaggy "bannana" bales, am going to try 1st cutting a little sooner to keep it from getting rank, and sharpen the knifes. Also noticed when an experienced farmer was running the bailer last year(I've only been farming 10 yrs.) he moved the bailer to adjust where the hay was on the pickup , and it seemed to make better bales, (fewer bannans). hope that helps, Shawn
