John Deere MOCO 1207
Devin Sparks
05-23-2006 16:00:51
I have found a JD 1207 mower conditioner that i am intrested in buying. Has anyone had any experience with these and what should I look for when I go to look at this machine.
Thanks
Devin Sparks
05-28-2006 09:53:06
 Re: John Deere MOCO 1207 in reply to Devin Sparks, 05-23-2006 16:00:51
Hey Guys,
Thanks for the advice on this mower. I bought it and it is in good to fair shape. The tin is rusty but what can you expect from something this old. It is out of time per the seller. I have run it and noticed that it bounces alot. Do you know how to get it back in time. I have a owners manual on the way. Thanks
Devin
Roger in Iowa
05-23-2006 18:42:51
Make sure the rubber is solid on the rolls. Sometimes if the rubber is damaged water can get to the steel underneath and the rubber comes loose. Tap on the rubber and you can usually
tell.
Non-clog or stub guards are a plus. They cut thru anything!
Roger in Iowa
Devin Sparks
05-23-2006 20:01:25
 Re: John Deere MOCO 1207 in reply to Roger in Iowa, 05-23-2006 18:42:51
Thanks for the advice...
Tx Jim
05-24-2006 03:57:11
 Re: John Deere MOCO 1207 in reply to Devin Sparks, 05-23-2006 20:01:25
Devin,be sure to check wobblebox and the bracket it bolts to. Look for cracked or mended mounting bracket as bracket is not easily repaired to where it will stay repaired. Check u-joints and yokes that drive conditioner rolls also as wear can let rolls get out of time. Tx Jim
Devin Sparks
05-24-2006 17:37:20
 Re: John Deere MOCO 1207 in reply to Tx Jim, 05-24-2006 03:57:11
I am not sure of what you call the wobblebox. Can you tell me a little more?
Thanks
Roger in Iowa
05-24-2006 18:55:21
 Re: John Deere MOCO 1207 in reply to Devin Sparks, 05-24-2006 17:37:20
The wobblebox is another name used for the knife drive case. Driven by a belt it changes rotary (sheave) motion into reciprocating (back and forth) to drive the knife (sickle). It is mounted on a plate by four bolts. Sometimes the mounting breaks loose from the frame because the knife (sickle) head was worn and hammered until the mounting failed.
Roger in Iowa
Devin Sparks
05-25-2006 15:07:59
 Re: John Deere MOCO 1207 in reply to Roger in Iowa, 05-24-2006 18:55:21
Thanks for the help.
Devin
